I have verified that the computer is communicating with the printer.
SOURCE: Print Width Issue
the issue you are having is DPI related, when data is sent to the printer and rendered it is dot for dot, so a Z4M 203dpi printer has about 800dots on the printhead where your printer has about 1200dots on the printhead. so when your software prints to dot800 thinking it is the edge of the label it is infact at 60%. there sould be an option in the software to configure around this. if not the is an option in the printer to convert DPI setting ie 150>300 or 100>200 and so on. but i don't thing you can make a 300dpi print as 203dpi
best of luck
SOURCE: Zebra Strip prints blank labels
Please download a new driver from www.zebra.com (don't use your old windows driver) and then this will fix the problem.
SOURCE: Zebra Z4M Communication
Yasemin, the most practical solution is to design your label on a software like a label matrix or zebra designer and print to a file and have the ZPL codes. Roberto Martinez Mexico [email protected]
SOURCE: Zebra SM4 label printer to change ZPL to EPL
You will need to change the firmware on this printer in order to be able to change the language. I don't believe this printer will allow you to change the language using the advanced options in the menu unless they have recently changed this.
Here is a link to the manual where it tells you where you can download the firmware for the printer and how to install it. It is pretty easy but if you have any problems, please get back to me and i will point you in the right direction.
SOURCE: HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
