Did you check your drain hose? Check out the drain hose going into the drain or where ever its draining into. MAke sure its not too far in the drain or to far into the sink, wherever it is draining into. Water may be syphening back into washer and pump is operating to long and washers senses it and stops. SO your washer fills up, goes into the wash cycle and washed normally coorect? It sounds like everything is doing what its supposed to do. I meen, you said you put a new pump. You checked the ppressure hose. The door latch sounds good because it supposed to lock when it goes into final spin (for safty reasons) . The pressure switch doesnt sound like its stuck open or closed, otherwise it wouldnt go into the wash cycle or your pump wouldnt turn on when its time to drain. You did say you hear your pump running? It does drain, correct? I would assume nothing is stuck in the pump because its new. Check your drain hose out to make sure it not how i described it. if so, readjust it and operate the washer again. if problem still persists, possibly one of the boards is mis communication for the final spin operation....but lets not assume its the boards right now, lets try the little stuff first....
If your washer fills to the correct level, agitates through the wash cycle, and then drains, I would check the door safety switch for proper positioning and switching operation. The switch should have minimal resistance (closed circuit) when it is depressed and high resistance (open circuit) when released.
frigidier mod atf6000es1
Frigidair ATF6000ES1 Checked door latch, board says door is locked and light is on for final spin. Even after water pump shuts off, the trap area(big black rubber trap)still has a lot of water in it. All the way up to the bottom of the spinning drum.
What brand and model number ?
whats is the model number and brand of washer ?
