Health & Beauty Logo
C
Cheryll Smith Posted on Feb 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I clear the 'L' error on my bathroom Salter scale. I have changed the battery but I cannot get the error to clear.
vince
Level 3:
  • Salter Master 2,530 Answers
  • Posted on Feb 14, 2018
 vince
Salter Master
Level 3:
Answers
2530
Questions
0
Helped
746566
Points
8845
New batteries? or one's that have been sitting around.
they may be low.
what they say to do...
1.
Open the battery compartment on the scale underside.
2.
Remove isolating tab from beneath the battery (if fitted) or insert batteries OBSERVING the polarity signs (+ and -) inside the battery compartment.
3.Close the battery compartment.
4. Select kg, st or lb weight mode by the switch on the
underside of the scale.
5.For use on carpet attach enclosed carpet feet.
6.Position scale on a firm flat surface. next......
INITIALISING YOUR SCALE
1. Press the platform centre and remove your foot.
2.'0.0' will be displayed.
3.The scale will switch off and is now ready for use.
This initialisation process MUST be repeated if the scale is moved. ie battery replacement.
Testimonial: "Thank you but the error is still not disappearing. I have bought new batteries twice now thinking the batteries were defective, yet I still have the 'L' appearing. There is not really any indication which way the + needs to be. I even tried moving that to different positions. I don't see an isolator tab that I can remove as per the instructions. That is the only think I have not done."
4 Related Answers
Anonymous
  • Posted on Oct 18, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Anonymous
  • Posted on Oct 20, 2009
SOURCE: The display on my salter bathroom scales is
I held the two arrow and set buttons together for a few seconds and it cleared
Anonymous
  • 10865 Answers
  • Posted on Mar 26, 2010
SOURCE: Salter 9001 bathroom scale stopped working
Hi Pete. I don't keep receipts either : ^ )
No that I am done commeserating, try this. Remove the batteries. Use the eraser end of a common pencil to scrub and clean the battery contacts inside the battery compartment. Also pull the contacts a little closer to the surface if you can. Then reinstall the batteries and you may be up and running.
Please rate my answer as verey helpful thanks. Joe
Anonymous
  • Posted on Aug 29, 2010
SOURCE: I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Error code bathroom scales
O-ld is 'overload'. There are some fixes here. The first thing I would do is remove the battery and leave it overnight. Replace the batteries with new ones. If you think it may be possible that you are overloading the scale, put a bag of sugar or flour on them to test.
https://www.google.com/search?q=Salter+bathroom+scales+0-ld+code
What batteries do I need for salter glass analyser scales
This pack of 2 high quality CR2032 batteries are ideal for Salter bathroom scales. Please check that this is the correct battery for your scales. With long shelf life, these CR2032 batteries are the perfect replacement.
7helpful
10helpful
Top Salter Health & Beauty Experts
vince
jws1013
Ngoro
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
