Search for:
Make Model manual
you may be lucky to find one online.
Thank you so much, have done that to no avail. Not to worry, thanks all the same. It was good of you.
Sorry. Maybe try these people since they still seem to sell that model, they might be able to get you at least a downloadable copy.
https://necchi.co.uk/products/necchi-sof...
Thank you once again R. A. Ellis. You're a star! I'll be on to it very soon.
SOURCE: making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
SOURCE: manual fornecchi-alco sewing machine model 301
I have an ALCO 2200. Luckily I have the manual. If some one need the manual, I can photocopy and send it to you, if you do not mind paying the postage. :)
SOURCE: I need a user manual for a Necchi Alco 2200 sewing machine
Contact the individual who posted this answer.
You should also try www.sewusa.com. I found the manual for a used Necchi 521FB I brought. Hope that helps.
