Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try
helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera
had been exposed to sand or dust, try blowing canned air on the lens.
If
this does not work, the lens assembly must be taken apart completely
and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.Lens Error.
