SOURCE: Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
SOURCE: I have a hobart dishmachine
Which tank is loosing water?
Number 1. Make sure all curtains inside are in place.Curtains help keep the water in the proper tank. For example, curtains are missing between prewash tank and wash tank, the wash tank water could be significantly splashing into prewash tank and out the p.w. tank overflow. Are you ruling out the drain because you replaced o-rings? Look at the floor drain as machine is running. Do you see a large flow of water going down drain? There is a drain heigth adjustment on the drain lift. Mabe the drain stopper is not dropping far enough.
Mike
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
SOURCE: I have LG WM1832CW washing
your drain hose is in the drain tube to far, pull out the hose and only put it in about four inches into the pipe. when you drain line is in to far the hose get a syhpon effect from your sewer.
SOURCE: LG WM1832CW water leaking
your valve is not closing or your cycle isn't reading correctly. there should have been a diagnostic read process that should have came with the machine. if not you may have to end up buying a new drian assembly
