What is the problem with the dryer?there is no reset button,if it doesn't start you could have a broken belt,or one of the thermostats is blown,the only way you could try to reset it is by unplugging it for a few minutes and then plug it back in,this will reset the computer board,or if you have no heat there is a resettable t-stat part 6931EL3003C if that's what you mean,and your dryer isn't electric it's gas,if you look at the model number DLG the G is for a gas dryer,go here hope this helps you out.
https://www.youtube.com/watch?v=EUqVqmEmrbQ
go here to see parthttps://www.repairclinic.com/PartDetail/...
this is on some gas dryers,you push the middle button in to reset it but what caused it to do this?while you're in there vac up any dust or lint you see and check the vent line to see if it's blocked with lint,if you have a long vent line i use a leaf blower to blow out the line,remove it from the back of dryer and stick it into the vent line and blow it to the outside,after you start the dryer go outside and make sure it's blowing good and the outside vent is opening,also go here to look up all parts in your dryer,put your model number in and look up parts
https://www.searspartsdirect.com/part-nu...
sorry forgot to mention when cleaning it out check the duct that the lint filter slides down into,and if you have a shop vac set it up to blow and blow out all the gas parts,you have an open flame in there and you don't want a fire,you should take the dryer apart and clean it out at least once a year and check the vent line so you don't have a dryer fire,also unplug it before you work on it.good luck,like i say all gas dryers don't have this resettable fuse but your model does,if you push it in and it doesn't click it could be bad and need to be replaced,also it could be something else if no heat,bad gas coils,sensor or igniter but the only way to tell is by getting in there with a meter to check,if you need anymore help write back.
SOURCE: i have a lg dryer model dlg2532w gas dryer it does get warm
if the cloths are warm and wet the problem is not with the dryer but in the venting. check the air flow at the end of the line (where the exhaust leaves the building) if the air baffels are not fully opening when the drier is on there is probably an issue with the venting. remember to tape up the venting joints after inspecting it because it is also the exhaust for the gas. hope this helps.
SOURCE: HOW TO INSTALL THE BELT ONTO A LG DRYER MODEL DLG2532w
Connect Gas Supply Pipe
(Gas Dryer ONLY)
For further assistance, refer to section on Gas
Requirements.
1. Make certain your dryer is equipped for use with the
type of gas in your laundry room. Dryer is equipped at
the factory for Natural Gas with a 3/8” N.P.T. gas
connection.
2. Remove the shipping cap from the gas connection at
the rear of the dryer. Make sure you do not damage the
pipe thread when removing the cap.
3. Connect to gas supply pipe using a new flexible
stainless steel connector.
4. Tighten all connections securely. Turn on gas and
check all pipe connections (internal & external) for
gas leaks with a non-corrosive leak detection fluid.
5. For L.P. (Liquefied Petroleum) gas connection, refer
to section on Gas Requirements.
SOURCE: LG DRYER DLG2532W GAS
I had similar problem with my LG DLG2532W gas dryer:
1) Power on machine:
- Check Filter light comes on (LG says this is OK at start)
- Time lights have all dashes
- All Program cycle lights on (Air Dry up to cotton towels)
- This is all normal
2) Select program cycle (cotton towels for example)
- Check Filter light now goes off
- Time shows 58 minutes
- Dry Level, Temp Control, etc are set automatically
3) Push start (this is where the trouble begins)
- The "drying cycle" light starts blinking (good)
- The dryer starts turning (this looks good...but)
- The ignitor (heating coil that ignites the gas) never heats
- The gas never comes on (because ignitor not on)
- No heat ever is produced.
Net result is dryer looks normal and runs, but there is no heat.
There is no error code...nothing to tell you anything is wrong.
Your only recourse is to call a technician because the manuals do not explain anything in any detail.
Thank goodness for the internet. I just needed the one clue that there was a reset button on the thermostat. That fixed my problem. Here is some more detail in case someone else is having this problem:
There are apparently two thermostats in the dryer. They are on the exhast tube that houses the burner element and the ignitor. One is on the top half of the exhaust tube near the dryer wall and the other is on the bottom half of the exhaust tube toward the center of the dryer. The one on the bottom half of the exhaust tube in the one with the reset button. Before pushing the reset button PULL THE PLUG ON THE DRYER OR TURN OFF CURCUIT BREAKER. The reset switch is between two wire leads that go to the thermostat and you will probably shock yourself if you try to push the button with the power on. If you open up the right side access cover on the dryer, then you can see the exhast tube. It is about 5 inches in diameter and (looking thru the right side access port), it will be sloping up from left to right as it runs from the front of the dryer to the back. You can see another exhaust tube further away from the port and lower down, but the one you are looking for is closest to you and higher up. If you look back toward the front of the machine (left), you can see two wires hanging down from the opposite side of the exhaust tube. The wires run to the thermostat which you can also see on a bracket standing off the exhaust tube. In between the two wire leads that run to the thermostat is the reset button.
Bottom line....pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minuite operation if you can get to the right side access port.
If you cannot get to the right side access port, you can pull off the fronf of the dryer and get to it that way, but it is much harder. You start by popping the dryer top by pushing in a putty knife between the top cover and front cover about two inches away from the top left and right edges of the machine. This is tricky and takes some fidling. I just pryed mine open the first time, but now I see how it is supposed to be done. After popping the top, you can take off the front of the machine. There are two screws on the top and then two more on the bottn half of the door. You have to open the door to get these two screws out. There are some wires going to sensors and switches that have to be disconnected.
It is much easier to access the thermostat thru the right side access port.
SOURCE: No heat in dryer and can't find reset button
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
SOURCE: I need thermostats for LG Gas Dryer DLG2532W in houston TX
Hi, you can order your replacement thermostat parts at the link below.
CLICK HERE
