User Codes are 4 digits long and must all be different to each other. A master Code must be
used to Change and Add user codes. The default master code is user code one [01] with a
code of [1234]. Any user code can be assigned as a master code (See User Code
Authorisation). Note the system must be disarmed before user codes can be changed or
added
This feature lets you change your personal passcode at any time, without
assistance from your alarm company. It is recommended that you write
down your old passcode and the new one before you begin.
1. Make sure your system is off (On light is off).
2. Press the [5] key. The OK tone sounds and the display changes
to:
3. Enter your current passcode. The Part light begins to flash and
the display shows your user number. In this example, the user
number is 4:
4. Entered a new passcode with the same number of digits as your
old passcode. If the error tone sounds, go back to step 1 and try a
different new passcode.
5. Enter your new passcode again. The OK tone sounds and the
system leaves the change passcode mode. If the error tone
sounds, start over.
Here is a link to download the manual.
http://www.minutemansecurity.com/mss/images/stories/userManualPDFs/bosch_2112&2212_userManual.pdf
