Question about Panasonic Televison & Video
SOURCE: Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Oct 14, 2008
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
SOURCE: PANASONIC PLASMA TC-P50C2 The tv
Hello
Your TV is in warranty period I thinks. If so, company is liable and will repair it free fo charge. There is "repair,replace, refund gurantees. Your gurantee card and broshure will tell you that. Look at it.
For what you are going to take the risk.
Posted on Mar 24, 2011
on Jun 08, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Jun 25, 2017 | Panasonic Televison & Video
Jan 18, 2016 | Panasonic Viera TC-P50G25 50" Plasma TV
Dec 06, 2015 | Panasonic Viera TC-P50G25 50" Plasma TV
Mar 05, 2014 | Panasonic Viera TC-P50G25 50" Plasma TV
Jan 02, 2014 | Panasonic TC-P58V10 Plasma TV
Mar 09, 2013 | Panasonic Viera Tc-p42s30 42" Plasma Tv -...
May 02, 2011 | Panasonic TC-P46G25 Flat Screen Plasma...
379 people viewed this question
