SOURCE: I have a Onkyo HT-S6100 sound system which has the
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
SOURCE: No sound from my AVOL tv
U have to use the Connector labeled RF-1 U have to screw the connector on. I had the same problem
Check the audio settings of PS3. You have find out the audio output format setting. Then select it to PCM. You will get audio.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Which source should i use bc i have the right spot but no pic or sound.
SOURCE: Trying to hook up a PS4 2A Oli flat screen TV help please
Support deep color 30bit, 36bit, blue-Ray 24/50/60fs/HD-DVD/xvYCC Amazon com MALLCROWN 4 Port 1080p HDMI Splitter with Ac Power adapter...
