Video Game Consoles & Games Logo
P
Patricia Bouton Posted on Feb 06, 2018
My emerson table wont hook up to wii fi - Video Game Consoles & Games
1 Related Answer
Anonymous
  • Posted on Jan 10, 2013
SOURCE: How do I hook up my Wii Console to my new Emerson
I found a better way and it works fine. I have a new 32 inch Emerson, with only one composit hood up ( which won't work with the wii) 2 HDMI's ( again does not hook up to the wii, the monitor hook up for PC, red and white ( yellow plus is not there it's for a stereo they told me), and the usb hook up ( which is more for pictures I was told by the company).The answer was to hook my RCA plus to the red and white under the composite, then hook the yellow into the green plug of the composite, and behold- my will now works fine.
MY EMERSON TABLET IS LOCKED ON THE PHONE PAGE. CAN YOU HELP ME?
you cangrab a laptp/computrand hook up your charge to itunes then update it
1helpful
I got a Emerson 50" on Black Friday! Wii on component input has no red in the picture.
Try another component video cable. It sounds like the red signal isn't getting to the TV.
How do you hook up the wii on tv so you can get netflix and tv channels?
You need to have wi fi access-go to wii options- then under the wrench to settings- then to internet connections.Cheers-Denny
Hooked up the wii to a new emerson tv. no cable is attached to the tv. the wii is showing up in black and white only, how can I get color
no your wii is in pal (UK EDITION) while your tv is NTSC( USA EDITION) so not compactible. So try seeing if tv has setting of switchin to pal if not sorry this means you can only by and play uk games if you got the wii in the usa its the opposite for you.
3helpful
3answers
How do I hook up my Wii to my 32" Emerson lcd hd tv? I have my dishnetwork satellite hooked into the dvd player and it's hooked up to the TV. On my remote I don't see a "game" button like my older Emerson...
Internet 4 wii
There is a USB adapter that you will need to buy that will enable you to use an ethernet cable to hook to your Wii to get internet.
I dont know how to connect my internet to my wii
the wii has a built in wi-fi reciever so you HAVE to have wi-fi if you dont buy a wireless router hook it up to your computer you need to have high speed internet for this then once your wi-fi is set up go to wii options internet connection then click search for connection if you have it set up right it will show your connection name then you click on it and it will retrieve the signal from your connection and you can go online from your wii.
18helpful
2answers
3answers
Cant connect wii to internet
The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
i hope this helps
2helpful
2answers
Wii remotes wont hook up
did you try syncing them up by pushing the red button on the wii and the remote
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
