The JBL Authentics L8 stopped working. Does not power on. When the power supply is on (underneath of the unit) the SOURCE button blinks rapidly. Something is wrong.
JBL AUTHENTICS L8 Service Manual (repair manual) is available to view online at https://servlib.com/jbl/audio/authentics-l8-sm8.html
alternatively you can subscribe (pay money) and download Service Manual.
Https://servlib.com/jbl/audio/authentics-l8-sm8.html
Shown in free demo mode to decide whether or not to purchase.
JBL AUTHENTICS L8 serv man8 Service Manual
Access free Product Manuals. Safe download. findproductmanuals.com
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
SOURCE: Mitsubishi TV WD-62527 will not turn on
Hi there, this is most commonly known as power board failure in the industry. the capacitors are blown. if you are experienced in inspecting circuit boards this will be helpful. you will have to disassemble and pull the power board and preform a break point test. the bown capacitors are easily picked out. they will be swollen and discolored. If you are not comfortable with disassembling this set, i suggest a service call. just tell the tech you are experiencing a power board failure.
SOURCE: Does anyone know which connector to plug into on power supply
Double check all the connections from the AC line and from the power supply to the other circuit boards. The connectors you are mentioning are identical as per the picture below.
If you need a new power supply, you can find one from this link.
Testimonial: "I have a few more questions that I would love to ask Jaime867. He produced a drawing of my circuit board within minutes and was a big help. Thanks"
SOURCE: Samsung LTM1755B
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it
on.
Solution: I just had one of these come in. I opened it up, and found
the U501 capacitor a little suspicious looking, in that it had a
deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I
replaced it with a very good quality 1000uF 16V electrolytic 105degC
10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to
turn it on, the LED was yellow for a second, then green, then I got a
picture, and it appeared to work great. I then asked the owner a week
later how it was working, and they said it was working just like new!
To find the authorized JBL service center in your area:
Try Manuals.lib and search for the item you're looking for. I tried to search for JBL Authentics but nothing. You might need to enter the exact model number or id#. Good luck!
Hi There, I am having the same problem with my Authentics L8 - flushing source button and no working- did you fix yours?
I had it serviced at the local repair shop. They needed to replace the power board I believe...
Price for Repair?
