SOURCE: PowerMac G3 connections and compatibility
You need a adapter from your serial port to usb/also yu need to update your os to 10.2 or 3
SOURCE: Connecting portable dvd player to tv
You should be able to connect the portable DVD player to the TV using an audio/video (AV) cable. The type of A/V cable you need depends on the receptacles on the DVD and the TV. Some older units have only one jack for audio and one for video. Newer units have one jack for video and two for audio. Matching the color coding of the cable, plug one end into the A/V out jacks on the DVD player and the other end into the A/V in jacks on the TV. I hope this solves your problem.
SOURCE: my DVD Writer is only recognised as a CD rom
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
SOURCE: DELSTAR DS700 netbook ultra-portable computer
go to delstar_manuals/ds700-netbook-manual.pdf. If you dont have adobe reader 9 intall it. your answers are there
SOURCE: I have an LG GP08NU40
Hmm, it seems that I have had a similar problem with my own dvd burner. Seems that the Laser used for DVD burning is broken or not working properly or you just need a firmware upgrade of your external DVD writer (you did mention reinstalling software, not firmware please clarify which one of the two it was).
OVERALL:
In case the hardware misbehaves - Get a cotton swab soak it a bit in alcohol and try to clean the laser eye-lens inside the drive that reads/writes on the disks. It is usually located when you open up the drive. *NOTE: dont use too much alcohol and let it dry completely before using.
In case there is a software issue - Download the latest firmware for the specific LG multi drive burner or ask more details/user manuals on the product on the official support page HERE. NOTE THAT this product is discontinued.
