Miscellaneous Logo
A
Albert Mwansa Posted on Jan 31, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i write prefix and suffix of my name - Miscellaneous
Clive
Level 3:
  • Master 882 Answers
  • Posted on Feb 04, 2018
Clive
Master
Level 3:
Answers
882
Questions
30
Helped
212839
Points
3292
Prefix Name suffix
The prefix is probably a title like Mr.
The suffix I guess would be (if applicable) things like Snr., Jr., Esq., or varsity degrees.
Pre=before.
1 Related Answer
Yogger
Max Quido
  • 117 Answers
  • Posted on Dec 07, 2010
SOURCE: What would I put under
Hello Norma, you can use the suffix or prefix to send characters, which are not included in the barcodes tgehter with the scanned barcode data.
If you dont need any character before or after the data, you can leave it blank.
It is usually used to add an Enter or Tab to switch to the next line, while scanning to some application like excel.
2answers
What is the definition of an suffix and a prefix i would like to know about it please give me information from the dictionary?
Prefixes and suffixes are grammatical and lingual "affixes." Prefixes are affixed before and suffixes after a base word or word stem to add information. For example, with the word "prehistoric," the prefix is "pre-" meaning "before," the base word is "history" meaning "recorded events and knowledge", and the suffix is "-ic" meaning "relating to the science of."
In other words, "prefix" simply refers to an attachment before or in front of, in this case, a shorter word or stem. In lingual terms, a "stem" is the main part of a word to which prefixes and suffixes can be added and may not necessarily be a word itself, such as "dod" in "doddle."
Similarly, "suffix" refers to an attachment after the end of an existing word or stem, serving to form a new word or functioning as an inflectional ending, for example, "s" or "es" to make for plurality.
Sep 30, 2014 • Games
What is the prefix of bell
"BELL" has no prefix because you didn't write one.
Some words can have several prefixes or suffixes. There is no answer to your question since you wrote a word without a prefix. It would be the same as asking what is the prefix of "manufacture" as this word has no prefix; however, if you asked what the prefix of the word "remanufacture" is, one could answer that the prefix is "re". If you asked what the prefix and suffix are of the word "re-manufacturable" I would answer with Prefix = re, Suffix = able.
Suffix for politics
Posted in the wrong section, unless you felt it was automative related? How about apolitical for a prefix, or political-less for a suffix.
1helpful
Suffixes
Compose does not have a suffix. It may be considered to have a prefix, which would be "com-". Com- as a prefix usually means "together."
Suffix of bruin
Does not have a suffix. Not all words have prefixes and suffixes!
What is the prefix and suffix for the word obsidian?
Its an Igneous rock, obsidian-esk could mean 'having similar properties to obsidian'. Pseudo-obsidian could describe a material that mimicks obsidian.
There is no real prefix or suffix, you can use different adjectives to describe it.
Prefix and suffix of segregation
Segregation
Segregate
"se" is the prefix meaning: "from" or "away"
"greg" is the root of the word meaning "group" or "united" or "union"
"tion" is the suffix meaning "result of" or "state of" or "act of"
"ate" (for segregate) would be the suffix meaning: "make" or "cause".
Hope this helped!
23helpful
Give examples of noun derivative
noun derivative - a verb that becomes a noun by adding a suffix.
You sometimes come across words which have been derived from their roots by adding certain structures like prefixes and suffixes.
In your earlier years of schooling, you must have been done with exercises and development activities on the use of prefixes
A prefix- is a group of letters added before a word or base to alter its meaning and form a new word. In contrast, a suffix is a group of letters added after a word or base.
5 Example of prefixes:
Prefixes MEANING EXAMPLES
ana- up, back, again analogy, anatomy, anagram
anti- against antipathy, antiwar, antisocial
apo- from, away from apology, apologize
com- with, together communal, community
con- with, together connect, confide conspire
there are so many example of this. i hope it helps. remember that an adjective derivative is a noun, verb and adjective that becomes an adjective by means of adding affixes.
In this lesson, you will deal with deriving words through the use of suffixes.
A suffix added to the end of a root word.
5 Example of suffixes:
Suffixes Meaning Example
-ics things having to do with optics, physics
-ism the belief in pacifism, terrorism, socialism, communism
-logy study field of biology, geology, etymology, cardiology
-or, -er one who takes part in doctor, actor, teacher, driver
-sis act, state, condition of analysis
We have, for example, a verb that becomes a noun by adding a suffix.
This is called a noun derivative
A noun that becomes an adjective by adding a suffix is called an adjective derivative
Example of Adjective Derivative:
subject- subjective
addict- addictive
react- reactive
success- successive
care- careless
ugly- ugliness
hope- hopeless
steel- steely
accept- acceptable
obey - obedient
These are but few ways by which we can identify how words are derived.
Removing leading zeros from barcode???
Prefix/Suffix Dialogs
The Prefix/Suffix Dialogs allows configuration of DataWedge options.
Two data entry fields are used to display and allow entry or editing of prefix and
suffix strings. The prefix string, if present, is transmitted before the data for any
barcode scanned. The suffix string, if present, is transmitted after the data for any
barcode scanned.
The following checkboxes are used to display and allow modification of various
DataWedge options:
Allow escapes in prefix/suffix (default = disabled)
Enabling this option allows escape sequences to be embedded in prefix and
suffix strings. Escape sequences allow non-textual data to be transmitted as
part of the prefix or suffix string. All escape sequences begin with the backslash “\”
character. The supported escape sequences are:
\b Backspace
\f Form feed
\n New line (line feed)
\r Carriage return
Apr 14, 2008 • Symbol MC70
Top Miscellaneous Experts
H Smith
Level 1 Expert
Robert
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
