Clean your print head. Pull the ink cartridge/print head out and dab a Q tip in distilled water and run it over the very small piece of foil that is the ink jet head in one direction, like your painting it. you will use about 15 to get it clean as it will constantly bleed ink onto the Qtip. When its clean, you should put it back in and run a printer head cleaning cycle through the printers tool section. It will print each color a few times on a line and that should clean the head internally.
SOURCE: Cannot print I Photo photos
have a look at
http://forums.macrumors.com/showthread.php?t=228117
you can set aol as the default email program by pressing start / then all programs or program / then you should see program access and defaults, use the program to set your email program settings all into aol. if you wish.
SOURCE: printed photo from email with bright red colors but came out pink
If you have tried a printhead clean then your printhead is faulty, email [email protected] and tell them about it. They will be able to send you a new one.
Testimonial: "Just a GOOD access and answers for problems"
SOURCE: How to fix colors running together
First, make the printer self test. If the problem continues, unfortunately your carriageappears to be damaged and is activating all jets when printing. Try to replace it to solve the problem.
