Question about Sylvania Televison & Video
Red lines in portable DVD player
Sylvania portable DVD player. How can you remove red lines in picture.
5 Suggested Answers
Anonymous
  • 2985 Answers
SOURCE: connection to a portable tv
The RCA set on a tv [Red /White /Yellow] are INPUT[ VCR/DVD player] not out put. Hook the speakers up the the 3,5mm earphone jack though you will need a conveerter plug like this
Posted on Jul 01, 2007
Anonymous
SOURCE: Too much red unable to adj it out
I am having the same issue only with blue lines. I was told to get the voltage adjusted. Can you tell me how to do this? Thanks in advance!
Posted on Dec 31, 2007
Bill Heronemus
  • 308 Answers
SOURCE: Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Posted on Apr 13, 2008
Anonymous
SOURCE: Connecting portable dvd player to tv
You should be able to connect the portable DVD player to the TV using an audio/video (AV) cable. The type of A/V cable you need depends on the receptacles on the DVD and the TV. Some older units have only one jack for audio and one for video. Newer units have one jack for video and two for audio. Matching the color coding of the cable, plug one end into the A/V out jacks on the DVD player and the other end into the A/V in jacks on the TV. I hope this solves your problem.
Posted on Apr 07, 2009
Anonymous
  • 814 Answers
SOURCE: my portable dvd player has sound but no picture on the screen. pl
If you still have use of the on screen menu functions, you can try using the restore to factory setting option in the preferences section of the set-up menu. Press the setup button on the remote control and use the up and down arrows to find and highlight the preferences section, press ok to enter the sub-menu.In the sub-menu use the up and down arrows to find and highlight the default option. Press ok. This will reset the dvd player to the factory settings. If you do not have the use of the on screen menu, you can use the a/v outputs to a external monitor or television to perform the abouve procedure to try to restore the dvd player to normal operation. If all this fails you can call Phillips customer support at this telephone number. 1-888-744-5477 They will be able to help you, either solve your problem or get the dvd player serviced.I hope this information helps you with your problem.
Posted on May 31, 2009
I have a Sylvania 32 inch DVD not reading the DVDs what's wrong???
How To Fix a Portable DVD Player That Is Not Reading or ...
? 17:12
https://www.youtube.com/watch?v=ucNedtR256g
Jan 18, 2015 - Uploaded by orly lando argallon
How To Fix a Portable DVD Player That Is Not Reading or Loading Discs. ... 2:32. How To Clean A DVD ...Missing: inch
Amazon.com: Sylvania SDVD9805/SDVD9805-C 9-Inch ...
www.amazon.com/Sylvania-SDVD9805-SDVD9805...
Amazon.com, Inc.
Rating: 2.9 - ‎916 reviews
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player. Sorry .... 5.0 out of 5 stars32+ hour car trip ... One remote does not work on both, only works for the one it came with. .... Garbage, 3 months in the first of the two DVD players stoppedreading the DVD's so we only used the one and now 5 months in the ...
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen ...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player at Amazon.com. Read honest and ...
Jan 20, 2016 | Sylvania Televison & Video
How do I switch to av out on my Sylvania portable DVD player
you dont need to,just plug yellow to yellow and red white to audio
May 09, 2015 | Sylvania Televison & Video
How do I turn down the volume on DVD portable Sylvania without remote
To turn the volume hold down the play/pause button
To turn the volume down hold down the stop button
Aug 31, 2014 | Sylvania SDVD1030-RED 10-Inch Portable DVD...
SDVD8732 7-Inch Dual Screen Portable DVD Player not displaying picture on screen
On one or both? Take a flash light and look close at the screen while playing something. If you can see the picture on the screens then it is a back light problem. They are not easy to repair.
Sep 05, 2013 | Sylvania SDVD8732 Player
No picture
Check the backlight inverter. Seek tech support.
Jun 06, 2012 | Sylvania SDVD8730 7 in Portable DVD Player
Sylvania SSD803 DVD Player / VCR Combo
Hi There, You are having a connection problem. Are you using a Yellow red and white cable? Can you provide details your connection from the back of your DVD player and Television. Thanks, Mike
Nov 03, 2008 | Sylvania SSD803 DVD Player/VCR
Televison & Video Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
