Ard isAll other keys seem to work fine.
SOURCE: GE Wireless Keyboard - intermittent keys
You can also gently flick off the relevant letters with a screw driver and clean the underside and the actual keyboard switches, but one at a time incase you forget where they go.
SOURCE: Logitech LX310 keyboard / mouse (wireless)
it works fine on my brothers computer but it doesnt work on mine, i dont really want to reformat either. any way of fixing it without reformat?
SOURCE: Gateway cordless KR-0401 Keyboard
I had the same problem. I solved it by pressing the connect button on the back of the keyboard and then pressing the connect button on the wireless connection base. The keyboard and the base will sync up again. Should solve your problem.
SOURCE: keys on keyboard not working properly
go control panel, hit mouse and find default settings. hit default, ok and do a reset on your computer.
If you have a special install disk for your mouse when the system starts back up ,test your keys then install the disk(or CD). if this does not correct your problem , check to see if someone changed the language on your pc. If english, buy a new keyboard.
SOURCE: Space bar, left-side enter key and backspace do not respond.
Try buying a can of compressed air and cleaning around those areas if you have spilled liquid on them ,that could be the prob as well
