Kitchen Ranges Logo
Glen Wagner Posted on Jan 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do you attach the wires on a replacement dual surface element on a whirlpool smooth top range?
Ken Strite
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 104 Answers
  • Posted on Jan 25, 2018
Ken Strite
Expert
Level 2:
New Friend:
Cheetah:
Answers
104
Questions
Helped
35098
Points
259
5 Related Answers
Anonymous
  • Posted on Mar 02, 2008
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Anonymous
  • 623 Answers
  • Posted on Aug 19, 2008
SOURCE: replacing a radiant element on
try this site for manual
http://kitchen.manualsonline.com/
Anonymous
  • 5911 Answers
  • Posted on Sep 19, 2008
SOURCE: How do I change the element on a Whirlpool Gold range?
If you have replaced the dual element with a new one, and have verified that you have the wiring installed correctly, it may be the infinite switch that controls the element that is bad. That would be the switch behind the control knob for the element in question.
Anonymous
  • 1136 Answers
  • Posted on May 30, 2009
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
Anonymous
  • Posted on Mar 31, 2010
SOURCE: Surface burner on electric smooth top range not
I have a GE Spectra smooth stove top and it has two burners in one, The problem is that the inside burner is not working. I need to find out how I can get into the stove to see how to fix it. Does anyone else have this problem and how did you fix it?
3helpful
How do i replace the surface element for a glass top cook top range
The cook top on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the front edge of the cooktop. You will need to open the oven door to see them. Then, just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There is dangerous voltage still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. The elements are fragile.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
If you have any questions about this repair, please let me know. You can reference searspartdirect.com for some helpful exploded view diagrams of you range for assistance if you need it. I hope you find this information helpful.
tip
Surface Burner Replacement on Electric Smooth Top Range
Steps necessary to replace one of the surface elements on a smooth top electric range.
Before you begin:
on Apr 05, 2010 • Kitchen Ranges
tip
This advice explains the steps necessary to replace one of the surface elements on a smooth top electric range.
The cook top will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the front edge of the cooktop. You will need to open the oven door to see them. Then, just follow these steps:
Before you begin:
on Dec 22, 2009 • Kitchen Ranges
2helpful
Opening the cook top in a Whirlpool electric range
The cooktop on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the frotn edge of the cooktop. You will need to open the oven door to see them. Just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
How to replace the glass for whirlpool oven serial # RPO 713144
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself. NOTE: Cook tops are NOT cheap. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
1. Unplug the cook top and leave the elements in place.
2. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
3. Remove the surface element assembly leaving all the elements wired together.
4. Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
5. Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
1. There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
2. Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
3. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
4. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
5. Lower the new cook top into place and secure with screws.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
2helpful
4helpful
Dual cooking zone burner not working
Okay...what you have is a dual element with the 6 inch coil burned out. Yes, this is repairable, but unfortunately, since this is a dual element, it is sold as one assembly. The part number for a replacement is WB30T10044, and you can find it at repairclinic.com for about $90 (repairclinic item number 824238). I know it isn't cheap, but it beats having to pay for a service call, or buying a new appliance.
If you wish to repair this yourself, you can do so by following these steps:
3.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the wire harness from the connector and follow these steps:
c. Remove the affected surface element. Take note of the numbered positions where the mounting screws are located and locations of the wires. You may want to write down the numbered positions and the wire color codes. HINT: A good digital camera can save you time if you have one. You will need to install the new element in the same manner.
d. Install new element (upside down). Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
e. Re-install the cook top back on the range and you are DONE.
NOTE: If your range does NOT have a disconnect plug on the wiring harness you will need to perform the repairs with the cooktop propped up, and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the element secure until you have it screwed back into place. Don't forget to remove the duct tape when completed. Once completed, lower the cook top and secure with screws.
I hope you find this information helpful. Let me know if you have require additional assistance.
2helpful
5answers
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
2helpful
2answers
Hot surface indicator
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
One of my burners is out, and I do not know how to get under the cooktop
You can check the element from the switch on the control panel. Unplug the oven, remove the back and put an ohm meter on r1 and r2 terminals to check resistance. If it shows open then the element is bad. If it shows resistance then replace the switch. To remove the top there should be screws under the front part of the top which you can see when you lower the door then just lift up. You won't be removing just the glass.
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
