SOURCE: Xerox copy center C35 - Replace Xerographic module
You can try this.
Press the access button, You will see a button called Enablement Code, then enter this number. *33886714351 .
Make sure you entter the * first, that is the button bottom left on the keypad.
That should allow you 5000 more pages. But it can only be done once. May or may not work on that product. But thats all I know.
SOURCE: how we solve the fuser moduleR3 temperature fault in the xerox machin of modul 5755
http://www.usask.ca/consumer_services/officecopiers/Replace_Fuser_Module_and_Ozone_Filter.pdf
if you have replaced the ozone filter also, ignore.
if not, shut down.
