SOURCE: magic chef electric dryer
Is there power to the Dryer? If so then Dryer most likely shut off due to a air flow blockage. This could be a clogged Lint Filter, or a Clogged Air Duct Exhaust (the hose that goes from your Dryer to the outsideof your house). If there is no air flow over the Heating Element the Heating Element will OVERHEAT and the Thermal Safety Fuse will Open cutting off the power. Some Thermals will re-set after cooling down. Others have to be replaced.
SOURCE: My Magic Chef Dryer 22lb Capasity Will Not Start.I
Try this web site I used it to repair my dryer.
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Hope this helps
SOURCE: Magic Chef dryer worked fine yesterday. We lost
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the machine ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video on youtube which showed me how to take my machine apart. This video (direct drive washer repair) made it possible for me to do my own repair. You probably don't have any idea of the wonderful help you can get from youtube videos. Your first stop should be at youtube. Just search for the help you need. You could search for "clothes dryer repair" or "clothes washer repair" or "dishwasher repair". If you are not able to view and/or download the videos, or after you've seen all you want to see, I suggest you go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers, dryers. and dishwashers as well as other appliances. Another excellent site is www.acmehowto.com If you have a direct drive top load washer and need help taking it apart these youtube videos are wonderful help. I was so impressed with them that when I saw all these people needing help, I wanted to tell them about the videos. If you look at the back of your top load washer and the panel is solid (no small inspection plate to remove, which would indicate you have a v-belt drive) chances are you have a direct drive and this video (direct drive washer repair) is just what you need. After you've seen all the appropiate videos, or if you have a belt drive washer, you will probably still need help in determining what the trouble is and how to fix it. I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Another excellent site for DIY help is www.acmehowto.com Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you where you can get help to solve the problem. Good luck with it.
SOURCE: magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
SOURCE: I've purchased a 4 wire dryer cord for my Magic
Hi, The green wire is simply the "ground" or "earth" wire, it has to be connected to the chassis/cabinet of your dryer. If there is no place to connect the wire which already exists you'll need to find a nut & bolt that will allow you to fasten it to the dryer. Hope that answer's your question. Thanks for coming to fixya. Macmarkus :)
