Video Game Consoles & Games Logo
Which is break control unit sir? - Video Game Consoles & Games
3answers
Kitchenaid oven will not turn off
HI,
The Electric oven control is defective.This problem requires a physical presence of a tech.There are no home remedies.Also let me know if there is any error code flashing.
4helpful
2answers
Hello sir, i forgot security code of Nokia 1680c-2 and please help me how to break it it's IMEI 355211035796220 my id [email protected]
Hello sir, i forgot security code of Nokia 1680c-2 and please help me how to break it it's IMEI 356841029369201 my id [email protected]
Jul 10, 2012 • Cell Phones
Sir i would like to ask you about the probl...
Try cleaning thermal prob.
And blowing out the controls.
If this does not work then one of them maybe bad.
Never work on a unit with out turning off the power to it.
And with many they may hold a power charge.
Canon3100 with code e000020-01a9 and -02a9 and -03a9, turned off. checked drum, fuser seems ok help
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
XX10 In INIT control of the initial setting,
SGNL is less than 62. Clean the ATR sensor window, Check on attachment of the developing unit, Check on a break
in the ATR sensor, Replace the ATR sensor
XX11 In INIT control of the initial setting,
REF is less than 62. Check on a break in the ATR sensor, Replace the ATR sensor
XX12 In INIT control of the initial setting,
SGNL is 960 or more. Check on a break in the ATR sensor, Check on operation of the shutter, Replace the ATR sensor
XX13 In INIT control of the initial setting,
REF is 960 or more. Check on a break in the ATR sensor, Replace the ATR sensor
XX50 When density data is computed using
SGNL value and REF value in ATR
control, REF becomes 0 due to backup
data corruption.
in the ATR sensor, Replace the ATR sensor,
Replace the DC controller PCB
XX51 When density data is computed using
control, the sensitivity coefficient
becomes 0 due to backup data
corruption.
XX81 P-SENS-P is less than 255 when a base
(drum face) of patch detection is read
out.
Clean the patch image reading sensor window
XX90 A computation result of patch reading in
patch detection is less than 16. Check on attachment of the developing unit, Replace the patch image reading sensor, Replace
the developing unit
XX91 A computation result of patch reading in
patch detection is 1008 or more. Check on toner leak from toner buffer in the developing unit, Replace the patch image reading
sensor
XX92 A computation result of patch reading in
patch detection is less than 42 for Y/M/
C and less than 73 for Bk 3 times in
succession.
the developing unit
XX93 A computation result of patch reading in
patch detection is 522 or more for Y/M/
C and 543 or more for Bk 3 times in
succession.
sensor
XXA0 In ATR control, SGNL is less than 62. Clean the ATR sensor window, Check on
XXA1 In ATR control, REF is less than 62. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA2 In ATR control, SGNL is 960 or more. Check on a break in the ATR sensor, Check on
XXA3 In ATR control, REF is 960 or more. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA8 In ATR control, the detected T/D ratio is
upper than its upper limit (13%) 10
times in succession.
developing unit, Replace the ATR sensor
XXA9 In ATR control, the detected T/D ratio is
lower than its lower limit (3%) 3 times
in succession.
BUT FIRST: Check the ATR SENSOR, left from the developing rotor you have an "rail" with atr sensor - vacume it!!!!! Vacum all dev units, and copier
2helpful
Service engine lite on Can it be from low octane gas
It can also be called the " Check engine light ".
In order to turn off the "Check Engine Light", you or a trusted mechanic check the Onboard Diagnostics (OBDII) OBDII uses a "code reader" which plugs into your car (usually in the dashboard, or near the radio...) and that tells you what "malfunction" is setting your Check Engine Light off.
Basically, if there is a fault in any computer controlled system (fuel, ignition, SRS (airbag), emissions etc) the Electronic Control Unit (ECU) sends a code to the OBD unit... Then the code reader breaks down the fault, it's location and usually (with a good reference manual) you can remedy the problem (or at least narrow it down!)
Thank you Sir, Have a nice day.
3helpful
4answers
52.00 error
Hp says you have a bad scanner unit(laser unit) or DC controller, but first reseat all your connectors on your scanner unit(laser) and DC controller. Your scanner is located under the top cover and the DC controller is located behind the right cover. If the problem still persist replace the scanner first.
4answers
How to change the resolution of Samsung SIR-4150
Featuring 520TV line horizontal resolution
in color mode and 570TV line horizontal
resolution in BW moe. The camera features
Sony’s 410,000 pixel CCD and capture
clean, noiseless high-quality image
Feb 25, 2008 • Cameras
1helpful
2answers
SIR-CL1 WIRING DIAGRAM
Here's the manual http://www.sirius.com/pdf/manuals/SIR-CL1_user%20manual.pdf Hope this helps.
2answers
Stays on even if HU (CDA-9833) is off
It is possible that the SIR unit stays powered as long as the red wire is powered, since it is normally connected to a switched source. To test this, disconnect the red wire or move it to a switched source (you could even add a switch on the wire and flip it manually). If the battery stays healthy after that, then the red wire being constantly powered is the problem. Otherwise, it is possible there is a problem with the Ai-NET cable connected to the SIR unit.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
