Paddle roller in the development unit is seized up. This is due to developer leaking in to the chamber where the gears sit on the front of the unit.
Short term repair is to remove small cover 1 screw and then remove gear and bushing 1 circlip.
Above will keep you running untill new part is fitted
Development motor: Bk: Lock Lock signals are observed at 2 sec intervals during motor ON, and a High level is detected at least 20 times
Causes
• Motor defective • Connector disconnected • Harness broken • IOB defective • Unit torque increased
Remedy
• Replace the motor • Reconnect the connector • Replace the harness • Replace the IOB • Replace the unit • Replace the driven unit
Developer assy locked up, its the lower part of the drum assy. Open right door turn gray handle to right and pull assy out.-Carl
SOURCE: Ricoh FT2260 Copier
There are basically two types of error codes:
These type of errors are often caused by the following conditions:
The VirtualReScan error codes displayed below are accompanied by descriptions and troubleshooting suggestions.
Let me know if u got help?
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
Good luck and please rate me, thanks.
SOURCE: Ricoh fax error #400
Possibly the fax line is open (busy). Try ringing the fax number, see what you get. Try unplugging the fax and plug a normal analogue handset into the line. See if you are getting a dial tone.
If not, then the cabling or line are faulty. Talk to your carrier. If yes then replace the cable on the fax (if possible) or have it looked at.
SOURCE: I have a Ricoh AFICIO
• Fusing thermistor defective
• Poor connection of the fusing unit
Inspect the parts
mentioned later:
Enter SP 5-810 (SC code reset) and select “1”. Then hold
down the Photo mode key and the ! key at the same time for
at least 3 seconds (this does not require the main switch to
be turned off and on).
If the problem
persists:
• Power supply board defective. Can have defective soldered.
SOURCE: error code E 1 on my Ricoh FT4418
please press (.) so we could see the last two number. but most probably check your exposure lamp and thermistor. maybe they are busted anf need to be replaced.
