Question about Microsoft Computers & Internet
Problems with a Microsoft keyboard set up. - Microsoft Computers & Internet
  • Brad Brown Jan 22, 2018
    Hi Wendy Read, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
'at' how to type email 'at'
You will have to check which country the keyboard is and which country your computer is set to. the most usual problems are in te UK with US set on the computer. In this case, the @ is where " is (shift and 2). Otherwise, try the very left-hand, top key which might have ` as a legend.
Feb 12, 2015 | Microsoft Comfort Curve Keyboard 3000
ITS LOCKED WONT TYPE MICROSOFT WIRELESS KEYBOARD
hi, that may be just software problems, try make troubleshooting to your wireless keyboard, { try to other computer }
if problems still same, mean your keyboard most likely have a problems
regards
May 28, 2011 | Computers & Internet
After using my Microsoft Wireless Comfort Keyboard 4000 for about 20 minutes, keys stop working in the middle of use. Current drivers are installed, fresh batteries have been used, I have uninstalled and...
Chances are that the keyboard is too far away from the receiver. This will wear the batteries down very fast. Optimal distance is less then 3 feet away unobstructed. try this and you shouldn't have many problems anymore.
Aug 16, 2010 | Microsoft Wireless Laser Desktop 4000...
How to install the microsoft comfort curb keyboard 2000
When you use a wired microsoft comfort curb keyboard, you may experience one or more of the following problems:
The keyboard is not detected.
The keys on the keyboard do not work.
Wrong characters are typed.
The keyboard shortcuts do not work.
Please visit below Microsoft website for the solutions.
http://support.microsoft.com/kb/258826
Regards,
Vijay
Jun 25, 2010 | Dell Dimension 3100 PC Desktop
Hepc 9602 not recognising keyboard
1. Check whether the wireless switch on the system is set to ON!
2. If there's any switch in your mouse/keyboard, set it to ON!
tell me if it helps...tc! :)
Jan 02, 2010 | Computers & Internet
Microsoft wireless keyboard 700 v2-0 not working
Your keyboard MS 700 v2.0 needs a USB receiver to work. They are pert of set. You may also have a wireless mouse MS-700 that is also part of this set.
1. Do you have the receiver ? This has a USB connector that must plugged in to your PC's USB port
2. Are the batteries in your keyboard dead ? If so change them for fresh ones
Then proceed with the instructions in the Quick Start Guide which can be found from this webpage
Microsoft Hardware
Note the light on the receiver only flashes when you press the 'connect' button. At all other times it is normally out. There usually no lights on the keyboard. You should not need extra drivers as they part of the OS if you are using Windows XP or 7.
If you still have problems see
Your wireless mouse or keyboard does not respond or you receive The...
or search on the internet for our specific case
8.March.2015
Dec 05, 2009 | Microsoft Wireless Optical Desktop 700 v2...
Keyboard problems
do the wireless connection in between the kbd and the computer again....
Apr 25, 2009 | Microsoft Multimedia Keyboard/Wireless...
Set up of a Microsoft wireless keyboard & mouse
The devices probably came with a USB cable and a receiver, or just a USB equiped receiver, that you need to plug into your computer. Go ahead and plug the cable and receiver into the computer so that your wireless mouse and keyboard has a means to communicate with the computer. Next, Here is a website address where you can download drivers for your mouse and keyboard. You must first choose either mouse or keyboard, then the exact product and model, then the operating system, and finally the language. repeat the process for the other device (mouse or keyboard, whichever you did not choose first). Good Luck! And let me know if there are any further problems.
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx
May 05, 2008 | Microsoft Wireless Laser Desktop 4000...
Keyboard map for Microsoft Wireless Optical Desktop Pro
when i go into keyboard properties there is no 'key settings' option
Jan 16, 2008 | Microsoft Wireless Optical Desktop Pro...
Open Questions:
Computers & Internet Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
