Looks like it is an older mechanical machine, so it may be seized due to old oil that has dried.
Wheel on right side that controls the needle up and down is very tight...
Possibly a gear or something is broken too.
SOURCE: have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
SOURCE: I need to replace the light bulb on my Elna SU 62C
Switch power off first. On the top left hand side of the machine towards the front is a small hole. Insert small screwdriver in hole and push down. The light bulb will appear underneath just to the left of the presser foot. Whilst holding down the screwdriver firmly, turn bulb anti-clockwise pushing slightly upwards at the same time. Bulb should dislodge.
SOURCE: service manual elna 722010 sewing machine
www.whitesewingcenter.com has the manual for an Elna 722010.
SOURCE: MANUAL for ELNA 62C ELNASUPER INDUSTRIAL SEWING/STITCHING MACHINE
i want learn gents shirts and phants how to learn i
