When looking at the tv, the right side is darker than the left. Do you have an idea what is happening?
One of the backlights may be burned out.
https://www.google.com/search?client=firefox-b-1-ab&ei=__VkWvivO8OyzwK_mJroCw&q=vizio+e60-c3+backlight+repair&oq=vizio+E60-C3&gs_l=psy-ab.1.4.0l10.141460.143995.0.150448.7.7.0.0.0.0.143.832.0j7.7.0..2..0...1.2.64.psy-ab..0.7.828...46j0i131i46k1j46i131k1j0i131k1j35i39k1j0i20i264k1j0i46k1j0i67k1j0i131i67k1j0i131i20i264k1.0._-yb4V0UHPk
SOURCE: Red 2 inch vertical line on right side of Vizio TV
That problem caused by a connection between LCD crystal and matrix driver,no tools yet to reconnect that metal to crystal connector,Claim warranty right away that will multiply or became larger.
SOURCE: right side of the screen is darker than the left h...
That is the sign of the power supply output is not at full output, you need to open it up and inspect the caps in the power supply first, look for caps with leaking/bulgin tops.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: I have a 46in lcd Vizio and the picture on it has
replace circuit board that lights up screen....a lot of little tiny transformers on them...u should have two(2) circuit boards that look alike ... 1 of them is bad!! replace ckt board.
SOURCE: left side blade cuts about an inch lower than
measure the height of cut from the ground to the bottom of the deck all the way around, if it is the same the blade or bearing housing is at fault, if it is lower on the left look for a bent or broken mount from the deck to the tractor on that side.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
SOURCE: Toshiba 57LX177: Right side of screen darker than left
I am not sure...but I have the identical problem. I believe the vertical lines are caused by the inverter board and the darkness is caused by the one of the back lights that needs to be replaced. I am tearing my unit apart now and will find out.
