I have gone through all the menu options but I guess I'm too illogical to locate the Adaptive DCR selection option in order to set it to ON. It is my understanding that Yamaha's default is OFF.
Hopefully the manual willl help:
https://www.manualslib.com/manual/1016519/Yamaha-Rx-V471.html?page=57
SOURCE: Menu Selection does not work
I had the same problem with the same player for some DVDs. Fortunately, for me, there is a solution that has worked 100% of the time.
I am assuming you are probably setting the DVD player to upconvert to 1080 i or p. What you need to do is go to DVD setup and change the resolution back to standard def (480i) just for the menus. The menus will now work properly. Once the movie starts you can switch it back to 1080i/p with no problem.
SOURCE: 3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
SOURCE: ricoh aficio 1035 factory rest now unable to get into settings
Press.
and # both simultaneously by but of 10 seconds until it is extinguished,
this restores the values of factory, with luck this had to solve it.
SOURCE: Can't turn the flash on...
check that you do not have the setting on burst as it will not be able to flash in this mode. when looking atthe screen about to take a photo, select menu, the first thingthat comes up is the mode, if it is in burst change in to normal and your camera should now have the option for flash or auto again :) good luck
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
