SOURCE: adjust expandable watch bands- Timex watch
Most expandable watch bands aren't sizable. IF it is sizable you will be able to tell when you stretch the bracelet out. If it looks like you can unlatch the links when you stretch it out then you might be in luck, but like I said, most are not sizable.
SOURCE: how to access older timex automatic watch second hand
You should be able to open the back by popping it off with a sharp knife blade. Sometimes, the lip where you'd open it is hard to see and usually under the band, between the lugs. The movement will just come out. If I read you right, you know how to do this, once the movement is removed. You can't just pull the hands off. Hopefully, you'll be able to just VERY EASILY bend the one that is causing the problem.
SOURCE: watch strap that holds face of watch separates and face falls off
mcdevito75 here, Besides online with Timex for another original strap, you can also look for a small watch repair shop in your area for a replacement strap.
