SOURCE: Urgently need user manual
These 3 links are for (in order): Daily programming (same time every day), 5day/2day programming, and weekly (different times each day) programming; http://www.kirklees.gov.uk/knh/publications/rwb9daily.pdf http://www.kirklees.gov.uk/knh/publications/rwb9daily%20wend%20day.pdf http://www.kirklees.gov.uk/knh/publications/rwb9daily%207day.pdf Hope this helps :)
SOURCE: nubira 2000 user manual pdf manual (english)
try this link to manual even though its 2004 manual is basically same just they updated info and put all paper based books into electronic form.(this link works !!)
http://www.onlinefreeebooks.net/automotive-machinery-power-equipment-ebooks/daewoo/daewoo-nubira-lacetti-service-manual-my2004-transaxle-drive-axle-pdf.html
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
SOURCE: Need service manual or electrical wiring diagram.
one ofthe best ways to work it out is the find the motor controller, normally it's a black box located under the seat,
Now remember you have two wires from the batteries B+, B-, two wires to the motor, M+, M- and some smaller wires on maybe a ten connector block that leads to the tiller where the throttle on the handlebars is located.
Hope that helps
Regards
GeWiz.
