Pool & Spa Logo
J
John Deere Posted on Jan 19, 2018
I want to reversenrotstion on my ao smith 3hp single phase 220v motor
Geoff Tuke
Level 1:
Habit-Forming:
New Friend:
  • Contributor 22 Answers
  • Posted on Jan 20, 2018
Geoff Tuke
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
22
Questions
0
Helped
5086
Points
35
Can't do it electrically. See if you can flip the armature and use that in that direction [bit of a long shot here - sorry]
4 Related Answers
Anonymous
  • 999 Answers
  • Posted on Jun 17, 2009
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Anonymous
  • 169 Answers
  • Posted on Nov 25, 2009
SOURCE: AO smith compressor motor missing toggle for duel voltage
Most motors will have a wiring diagram on them with numbers not colors, and show the wiring configurations for both voltages. If you do not have this then you may want to contact a motor shop and see if they can get it wired for you.
Anonymous
  • 248 Answers
  • Posted on Oct 09, 2010
SOURCE: I want to reverse rotation
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
john224
John Prohaska
  • 1378 Answers
  • Posted on May 24, 2011
SOURCE: My pool originally had a
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
How to change a 3 phase to single phase motor
You cannot change a 3 phase motor into a single phase motor because the windings are different in these motors. You need to buy a single phase motor to replace the 3 phase motor.
1helpful
I purchased a 60 gallon compressor from Lowes which has a 230 volt single phase motor,3450 rpm,15 amp. The model # of the motor is 7-194160. There is no wiring diagrm in the manual. I was wondering where I...
There may be a wiring diagram either on the body of the motor or inside the wiring terminal cover.
A.O. Smith can be contacted at 800-262-6484. If you do call, have pertinent motor info ready.
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
2helpful
How do i convert motor from 120v to 220v
you should have a label on the pump that shows the connections. 120V=low voltage 220V=high voltage. Here is an example of a label:
Conect the internal motor wires to the terminals indicated. Then connect your line to the terminals indicated
1helpful
2answers
I have a motor running 3450 rpm 230 volt 9.6 amp what is my horsepower?
Ok, but I need to know a few things;
Single phase motor or 3 phase motor?
What is the % efficiency?
Need to replace back half of a.o smith pool motoer
Do you mean A.O. Smith motor? This is the back half of
the Pool Pump. A.O. Smith motors are the most common motor drive for household pumps, so I believe
that you can easily find the replacement. Just specify
the horsepower (HP) rating, voltage: 220/110, single
phase or three phase. Just send your e-mail comment
for more info. God bless you.
3helpful
Wiring a 220v single phase motor and capacitor
Starting three phase pump
First you need to have 3 phase power. Almost no households have 3 phase power availble. You would need to get a three phase converter which would cost as much as a new pump. If you have three phase power you will need a 3 pole relay that is triggered from a timer and rated for the current of the motor.
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
