Question about Samsung Televison & Video
Samsung LCD model ln40b500p3fxza stopped turing on. No standby light. Replaced power supply board part BN44-00264B TV still does not power on. What else would cause it not to power on??
    Master:
  • Samsung Master
  • 362 Answers
Posted on Nov 05, 2019
  • Samsung Master
  • 727 Answers
Apart from power supply the main board also has to work for your tv to turn on. You have already replaced the power supply board. So the only thing left is the main board.
Posted on Jan 19, 2018
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Posted on Jan 30, 2008
tvservice306
tvservice306
  • 458 Answers
SOURCE: ln40a530 samsung lcd tv wont turn on
MAY BE PANEL LAMP BAD
Posted on Oct 21, 2009
Anonymous
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
mislamy15m
Majeed Aldamah
  • 4 Answers
SOURCE: Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Posted on Aug 28, 2011
SOURCE: will a power supply for a 50" plasma TV work with a 42" plasma TV?
sir it will work with your TV..
Posted on Mar 30, 2012
Have samsung tv model ln40b500p3fxza sound but no picture back light out,led in front flashes 5 times only.There is a dark image on the screen if you use a flashlight.How do I trouble shoot this.?
You won't find a Samsung schematic unless you're a factory authorized service center. Now for the good news you won't need one, this is a backlight issue most likely, I repair10 sets with LED's in the panel bad to one that has power board issues, the power supplies on Samsung are well made and don't give many issues
May 08, 2018 | Samsung Televison & Video
No Picture on Samsung Tv model UN40EH5300f. Standby light is now on after installing new power supply. Need help on which part to buy now, inverter or mainboard?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board./
Mar 04, 2018 | Samsung Televison & Video
I have a samsung tv model ln40b530p7nxza that wont turn on the standby light stays on solid and when i hit the button nothing happens i have replaced to main board and power supply board it is not a bad...
I didn't pull up the manual on this set but if since its a LCD set and the power board didn't fix it I'd look to the inverter board unless its built into the PS
Nov 25, 2017 | Samsung Televison & Video
Why is my Samsung lcd tv stuck on standby
Theres probably a fault in the power supply board and the tv is shut down to protection mode
Sep 22, 2014 | Samsung LA40A450 40 in. LCD TV
My samsung 40# shut off and won't come back on model# LN40B500P3FXZA please help
set has a shutdown or failsafe circuit:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Mar 31, 2012 | Televison & Video
I have a LG 32LG3000 LCD TV and the power light continually flashed red and the tv does not turn on.
Tries tv unplug,replug it back like about an hour later.See,if the tv will resetting self and working again.Not.The tv power supply board it is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 06, 2011 | LG 32LG30 32 in. LCD HDTV
Televison & Video Logo
258 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
