Optics Logo
A
Anonymous Posted on Jan 17, 2018
I have a Hopkins & Allen XL No 2, however the patent date on the barrel IS NOT EXACT & different than most others I have come across.
The top line of the barrel says Hopkins & Allen MFG. Co. Below that it says PAT. MAR.28. 1871 APR. 27. 1875 Then on the gun portion itself, above the cylinder, it says XL No 2 after disassembling it's number matching M3392
Bill Boyd
Level 3:
Top Expert:
  • The Master 53,816 Answers
  • Posted on Jan 17, 2018
Bill Boyd
The Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949290
Points
172802
Patent numbers mean little in trying to determine a date of manufacturer
and original patent number could be issued and the product put into production then years later to make an improvement a new/ modified patent is to improve the product
2 Related Answers
Anonymous
  • 132 Answers
  • Posted on Mar 29, 2009
SOURCE: bright horizontal line across black tv screen
Hi There,
If your picture has collapsed to just a horizontal line across the center of the screen, this indicates that your Vertical Output circuit is bad and needs to be serviced by a qualified technician. I hope this helps and thank you for using FixYa!
KingDWS
Dave King
  • 1606 Answers
  • Posted on Mar 24, 2010
SOURCE: Winchester 12 ga defender mod 1300 mfg. date
I think you might have better luck contacting winchester support or one of the bigger gun stores or even an online gun forum as this isn't quite a spotting scope question ;-]
http://www.winchesterguns.com/customerservice/index.asp
They should be able to tell you if the barrel is available and maybe how much or what dealer has one.
The 1300 was made from 1978 to 2006 so that should narrow down the date at least.
Testimonial: "I appreciate the information, some mentioned th "L" in front of the S/N designationing something but I dont recall thanks Dizzie78"
1helpful
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 • Firearms
1helpful
I bought an Iver Johnson single barrel 12 guage shot gun. Can anyone tell me about this gun?
It was built on the 1890 Hopkins and Allen patent and is very similar to several dozens of inexpensive single shot shotguns.
Dec 02, 2014 • Optics
Top The Optics Experts
NOEL
NOEL
vince
Are you a The Optic Expert? Answer questions, earn points and help others
