Hello, Bobbie -
You should be able to find the instructions for setting your model of Magic Chef microwave in the user's manual. My guess is that you do not have a user's manual for the MCD795SW.
This is the link to the page on ManualsOnline.com where you can open the PDF file for free and choose to save the manual:
http://kitchen.manualsonline.com/manuals/mfg/magic_chef/mcd795sw_1.html
See Page 7 of the manual to learn how to choose the power level you want.
Note: You will need Adobe Reader software (free) because the manual is in PDF format. When you save the manual document, be sure you name the file you save it to in your Documents folder with a file name you can find easily - something like: Magic Chef Microwave Manual. You will probably want to print the manual for easy reference.
Best wishes.
SOURCE: Magic Chef Microwave Model MCO160S .
You can download that manual here.
SOURCE: magic chef over-the-range microwave shut off
I have a Magic Chef Microwave Model MC0153UB that is shutting itself off while cooking. I noticed before this, the light under the microwave blew during a storm. Do you have any suggestions?
SOURCE: Magic Chef Microwave runs but no heat produced,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uitot
SOURCE: When I try to change the power level on my Magic
The oven always starts at 100% power. When you enter a power level from 1 to 9, the control board reads it as 10 to 90% of full power. So power level 5 is 50%, 3 is 30% and so on.
Testimonial: "Thank you for your quick response! Maybe now I can enjoy a potpie crispy instead of doughy! LOL!"
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
