Cars & Trucks Logo
A
Anonymous Posted on Jan 16, 2018
Ficht ram injection 75 hp evinrude. Model e75fplsnf what is the correct part number for the oil lift pump and injector assembly?
vince
Level 3:
  • Cars & Trucks Master 2,530 Answers
  • Posted on Jan 16, 2018
 vince
Level 3:
Answers
2530
Questions
0
Helped
748961
Points
8845
Not sure but here is the parts breakdown for the whole motor. You should be able to locate what you need from here.
https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=2002&hp=75&model=E75FPLSNF
hope this helps you.
5 Related Answers
A
Anonymous
  • Posted on Sep 05, 2008
SOURCE: Problems with Lift pump and
we have a 2005 dodge diesel, has been in the shop 3 times for the same problem.! lift pump.,failure, and fuel filter failure,
Does any one out there have any feed back,?? I filter all of my fuel after i buy it , before it goes in truck.... This is getting expensive,, HAS ANY BODY ELSE HAD THIS PROBLEM???
Need a attorney and some advice..
STRANDED,,!!!!!
txkjun
John Weathers
  • 409 Answers
  • Posted on Dec 29, 2008
SOURCE: 1999 Volkswagon beetle turbo diesel injection pump
Was any work just done to this car? Timing belt? It is rare that these pumps go bad but I have seen a few shell out. If you are not familiar with the ALH diesel engine I would not try to replace it. You should take it to a shop that specializes in VW's.
strive2endur
  • 14 Answers
  • Posted on May 02, 2010
SOURCE: 6.2 diesel will not bleed diesel
Make sure all lines are light when turning engine over.While turning engine over loosen the a line closes to pump or the fuel filter.You should get some fuel.Then continue on all lines working farther away.
Knight 007
Murtaza Akberali Versi
  • 767 Answers
  • Posted on Aug 18, 2010
SOURCE: I fixed used injection pump to engine and is not
1) There could be an air lock to the fuel system, try to bleed the system.
2) If the fuel is reaching the injector pump & not supplying to the injectors nozzles thn the pump needs attention.
Hope this helps!
czaa
Arnie Burke
  • 7339 Answers
  • Posted on Nov 29, 2012
SOURCE: lack of power
u need a repair manual-haynes or other for that model--
My Evinrude Ficht 200 fuel injected, while running above 200 RPM has no problems but when idling the no oil alarm goes off and there is plenty of oil in the tank.
Its the oil sensor in the oil tank...does the oil line bulb stay pumped tight? If not. you need to do some investigating...or replace the bulb and line..
tip
Caterpillar Fault Codes
CID code Name
1 Injector? 1
2 Injector, cylinder number 2
3 Injector number 3
4 Injector number 4
5 Injector, cylinder number 5
6 Injector, cylinder number 6
7 Injector number 7
8 Injector number 8
9 Injector number 9
10 Injector number 10
11 Injector number 11
12 Injector number 12
13 Injector number 13
14 Injector number 14
15 Injector number 15
16 Injector number 16
17 The fuel shut-off valve
18 The fuel control valve
19 Bypass valve accelerator
20 Device change timing of fuel injection
21 Position Sensor Engine
22 Sensor fuel injection advance
23 Drive Racks
24 position sensor rail
27 is a variable geometry turbocharger number 1
28 Drive with variable geometry turbocharger number 2
41 Power ECU (electronic control unit) 8 V DC
42 Valve inclusion nozzles
70 contact with the parking sensor
71 Timer stop idling
75 Oil temperature sensor circuit hydraulic steering system
The pressure sensor 81 at the inlet trap foreign particles
82 Pressure Sensor pnevmozapuska
84 speed sensor
91 Accelerator pedal position sensor
94 Pressure Sensor fuel pumping
95 The differential pressure sensor on the fuel filter
96 Fuel level sensor
98 Oil level sensor in the engine
99 The differential pressure sensor on the engine oil filter
100 Oil Pressure Switch Engine
101 pressure sensor crankcase gases
102 turbo pressure sensor
104 Oil pressure turbocharger
105 temperature sensor intake manifold
106 sensor input air pressure
Pressure sensor 109 of coolant downstream of the engine
110 Coolant Temperature Sensor Engine
111 level sensor, engine coolant
The differential pressure sensor 112 to filter engine coolant
124 gearbox oil level
126 differential pressure sensor on the oil filter transmission
127 Oil Pressure Switch gearbox
138 Mode Switch low traction
139 Solenoid tip ago
140 Solenoid tip forward
141 Eco Mode Switch
142 position sensor door to clean the radiator
143 contact pressure sensor control unit neutral
144 horn relay reverse
145 power supply circuit 12
146 Mode Switch hitch
147 pressure sensor lock-up clutch
148 pressure sensor in the hydraulic stroke
149 Three-way solenoid stabilization system of the implement when driving
150 Speed Sensor trambovatelya
151 Solenoid trambovatelya
152 diagnostic lamp control systems course
153 speed sensor right drive motor
154 RPM Sensor left actuator motor
155 solenoid switching stroke
156 Solenoid right turn in reverse (electronic display)
157 Solenoid left turn in reverse (electronic display)
158 Solenoid right turn forward direction (electronic display)
159 Solenoid left turn forward direction (electronic display)
160 Relay working equipment paver
161 brake sensor (chassis) pedal
162 Sensor Steering Wheel
The steering angle sensor 163 rotation
164 Pressure Sensor inclusion nozzles
167 Sensor charging voltage of the alternator
168 Electric system
171 of the ambient air temperature sensor
172 temperature sensor in the intake manifold
174 Fuel temperature sensor
175 Temperature Sensor Engine oil
177 oil temperature sensor Gearbox
190 RPM Sensor engine crankshaft
191 sensor output speed gearbox
248 data channel of Caterpillar
249 data channel J1922 SAE (Society of Automotive Engineers)
250 data channel J1708 / J1587 SAE (Society of Automotive Engineers)
Block 252 calibration
253 Personal chip control unit
254 electronic control unit
256 Map adjusting engine performance
257 Level detonation
258 sensor crank angle
259 set via software point fuel injection
260 oxygen sensor in the exhaust gas
261 the fuel injection timing calibration
262 circuit sensor supply 5 V
The power circuit 263 digital sensors (8 or 12)
264 pedal revolutions reduction
265 Input circuit stopping the engine, user-defined
266 Input circuit dry scroll engine (without fuel injection)
267 Chain input remote control signal Safe Stop engine
268 Error programmed parameter
269 circuit sensor supply
Code 270 cable computerized monitoring system (CMS)
271 Sound the alarm
272 sensor has exceeded the allowable turbo
273 pressure sensor at the outlet of the turbocharger
274 atmospheric pressure sensor
275 pressure sensor at the entrance of the right turbocharger
Pressure transducer 276 at the input of the left turbocharger
277 sensor calibration injection timing
278 The indicator light turn on the automatic control of engine speed (AESC)
279 coolant temperature in the intercooler front section
280 temperature sensor gear
281 The indicator light necessary Engine
282 Light indicator exceeding the permissible engine speed
283 Indicator Light air filter
284 Radio on EMS (electronic control system) (the signal of the engine)
285 overheating indicator light, engine coolant
286 Indicator light low oil pressure
287 Miniature digital output? 7
288 Miniature digital output? 8
289 Fuel pressure - before the fuel filter
290 pressure sensor in the pump drive engine cooling fan
The solenoid 291 engine cooling fan
292 solenoid hydraulic oil cooling fan
293 power analog output? 3
294 power analog output? 4
The control unit 295 hydraulic excavator heavy-duty
296 gearbox control unit
297 all-wheel drive system control
298 The probe brake pedal
299 position sensor gear lever
300 The primary windings of ignition coils
301 The primary winding of the ignition coil? 1
302 The primary winding of the ignition coil? 2
303 The primary winding of the ignition coil? 3
304 The primary winding of the ignition coil? 4
305 The primary winding of the ignition coil? 5
306 The primary winding of the ignition coil? 6
307 The primary winding of the ignition coil? 7
308 The primary winding of the ignition coil? 8
309 The primary winding of the ignition coil? 9
310 The primary winding of the ignition coil? 10
311 The primary winding of the ignition coil? 11
312 The primary winding of the ignition coil? 12
313 The primary winding of the ignition coil? 13
314 The primary winding of the ignition coil? 14
315 The primary winding of the ignition coil? 15
316 The primary winding of the ignition coil? 16
317 load cell
318 Right knock sensor
319 Left knock sensor
320 RPM Sensor / injection timing
321 Key switch reset / diagnostic confirmation
322 engine stop switch
323 The indicator light engine stop
324 Alarm lamp
325 detonation caused by the ignition system
Detonation System 326
327 Wrong number of knock sensors
328 Wrong number of cylinders of the engine
329 Error Link
330 Login with contact sensor propane content
331 Ignition Switch
332 keyboard switch
333 switch alarm
334 Reserve output
335 solenoid screw scraper
336 switch engine control
337 Remote Switch emergency stop
338 Relay pre-lube pump motor
339 contact pressure transducer pre-lube the engine
340 solenoid shut-off air
The solenoid 341? 4 warm-hydraulic distributor
342 Auxiliary speed sensor engine crankshaft
343 injector NOx catalyst in the exhaust gas
344 Relay injection pump converter of nitrogen oxides in exhaust gases
Pressure sensor 345 of the injection NOx catalyst in the exhaust gas
346 Relay stabilization system of the implement when driving
347 solenoid feed control (working volume) motor hydrostatic transmission
348 lock switch gearbox
Solenoid 349 gearbox synchronization
350 position sensor rod lift
351 position sensor rod misalignment
352 Sensor lift lever (in the cockpit)
353 sensor lever skew (in the cockpit)
The solenoid 354? 1 lift
The solenoid 355? 1 lowering
The solenoid 356? 1 unloading
357 Solenoid No. 1 return
358 Drive pressurization of the control loop hydraulic system work equipment
359 solenoid locking lifting
360 solenoid lock lowering
The electromagnet 361 tilt lock to download
362 solenoid control the fan speed of the engine
363 Drive stabilization system of the implement when driving
364 pressure sensor piston cavity lift cylinder
365 switch for limiter
366 contact gauge semiautomatic recess
367 Switch stabilization system of the implement when driving
368 switch, automatic / manual mode transmission
369 Login with shift indicator on the gearbox
370 Solenoid floating position arrows
Solenoid 371 beep
372 solenoid opening bucket (for excavator shovel)
373 solenoid closing bucket trucks through the hinged bottom (for excavator shovel)
374 Solenoid swing brake
375 Solenoid swing brake
376 Warning stroke
377-way solenoid brake
378 solenoid automatic lubrication system of the machine
379 Pressure Sensor automatic machine lubrication
380 contact pressure transducer modulation shift gearbox
381 Contact neutral position sensor lift lever (in the cockpit)
382 lever position sensor coupling
383 position sensor coupling
384 shifter
385 contact sensor neutral position tilt (in the cockpit)
386 solenoid lifting hitch
387 Solenoid lowering hitch
388 Contact line solenoid coupling
389 The probe neutral auxiliary lever
The solenoid 390 controlling the flow of hydraulic oil through the forward clutch
The solenoid 391 controlling the flow of hydraulic oil through the reversing
392 solenoid oil supply
The solenoid 393 to drive the front wheels
The solenoid 394 controlling the flow of oil through the drive motor
395 solenoid switch actuator pressure of the front wheel
396 Light on lamp-wheel drive (AWD)
397 contact pressure transducer feed pump
398 pressure sensor in the front wheel drive
399 sensor to the control lever-wheel drive (AWD)
400 The secondary windings of ignition coils
More Fault Codes HERE Caterpillar DTC
on Dec 20, 2016 • Cars & Trucks
1968 ford 2000 tractor 3 cylinders number 1 cylinder isn't getting fuel from injector pump the other 2 are is pump bad or not primed right
You need to ensure that here are no vacuum leaks in the line from the tank to the lift pump, the lift pump which looks very similar to a car petrol pump must be in good working order ie able to pump the minimum pressure and volume at cranking speed and idle speed.
If the lift pump is not working properly it will cause cavitation at the injector pump that will cause low pressure bubbles on the intake of the injector pump. If you have a good lift pump and there are no vacuum leaks between the tank and the lift pump then it may be down to bleeding the air out of the injector lines first at the pump, and then at the end of the injector lines (be very careful the diesel is at 170 to 175 times atmospheric pressure which is about 2500 pounds per square inch (which can penetrate skin deeply and even bone). Most of the Ford tractors use a rotary injection pump. Having only one cylinder not pressurizing is extremely unusual, try swapping the injectors between cylinders to see if it is a faulty injector, making sure to use new or at least anneal the old copper sealing washers and tension the injectors evenly with a tension wrench to correct torque. If the misfire then follows the injector it means your need the injectors servicing. New needles & nozzles for injectors is a lot cheaper than a new or rebuilt rotary injection pump. Please advise if it’s an inline pump. (which I doubt they were rare because they cost more).
2answers
Injector pump problem
fuel filter, computer
1helpful
Oil is being pumped to my Carburetor on my 86 Buick Regal .. Don't know if it happen before or after my oil change .. Does anyone know wat this could be ? This is were it's coming from .. I put a...
Your picture won't come up. If you are getting oil in the air filter housing, check your pcv system (Positive Crankcase Ventilation). Your pcv valve may be plugged or not working.
And just so you know, it is not a carburetor. It is a throttle body assembly with throttle body injection. You have fuel injection with injectors mounted in the assembly-much more reliable than a carburetor.
1helpful
2000 dodge ram diesel 2500 . What is a fuel injection pump mechnical failure? a fuel valve feedback circuit?
This usually happens when the lift pump gets worn and fuel pressure drops below 7lbs and the injection pump has to work harder by pulling in the fuel and will destroy the pump,your is probably a vp44 fuel injection pump it needs replaced and they are expensive 1200.00+ but also change the lift pump or change to a fass fuel system,if the lift pump went out and you replace the injection pump it will ruin it in a short time.
The injection pump is not an easy job to change or for a novice mechanic as it has to be set in time with the engine at top dead center,and then the whole fuel system needs to be bleed of air.
Hdi 2lt loss of engine power stalls
Have you driven through deep water?
Many possible faults, main ones are:-
Air or water in the diesel.
Use of Biodiesel/veg oil
Faulty injector (uncommon)
Crank Sensor
Leaking injector sealing washer.
Lift pump in fuel tank has broken up, particles may have reached injection pump and damaged it.
1helpful
2answers
99 ram diesel wont start
Did you check to see if there is power to the glow plugs if not then that may be the problem and if there is power when you cycle the key not to start but for the plugs to warm up you may have a bad glow plugs.
3answers
Ran out of diesel on a 2002 dodge ram 2500 cummins...need to know how to bleed the system
just bump the ignition without starting it let sit for 20 seconds oruntill you hear lift pump shut off then shut off ignition and repeat do it 2 or 3 times should start then cummins is a self priming system has been for years even in semi trucks
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
