SOURCE: GE JVM1651 Microwave
The control circuit board needs to be removed and repaired. We routinely repair these from customers nationwide for $32.50. It sure beats the cost of a new board!
SOURCE: Sears Kenmore Microwave Touchpad
Replace the touch pad .Costs around $49.00 -up.
PLEASE LEAVE A RATING !!
SOURCE: kenmore microwave model 665.61629100
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
SOURCE: microwave trips circuit breaker when plugged in
The circuit is probably a 20Amp circuit (see the number stamped on the circuit breaker switch). Most likely, it is the same circuit as the refrigerator, crock pot, window A/C unit, etc....
Also, if you are using an extension cord or a power strip or a surge protector. Those may not have a high enough power rating.
One other possibility (not likely) is that the circuit breaker is a 15Amp and the microwave is 1500 watts.
What else is cut off when the circuit breaker is tripped?
Solution is to use a different outlet for the microwave, or turn off any other applicance in the same circuit (except the refrigerator, of course).
Hope this helps!
SOURCE: my microwave oven keeps tripping the circuit
If a fuse inside had blown, that would definitely reduce the current flow rather than trip the breaker.
I have replaced several breakers over the years; they no longer last forever.
Try your Amana on a different circuit, not in the kitchen; if that other circuit likes the oven, the breaker is bad.
If the alternate circuit breaker also trips, then you have not a blown fuse in the Amana but rather a shorted component inside and repairing the oven will likely cost about the same as replacing it.
