I just bought this printer I downloaded kodak easy share disc, I try to open it nothing happens. My computer reads the printer as unspecified not printer then when i first plug it in the lights come on makes a little noise then lights go off and its silent.
SOURCE: Kodak Camera V610 easy share
Hi!
This is what I need you to try..
If you're using a 5v ac adapter to charge the camera's battery - please hook it to the camera WITHOUT THE BATTERY in it. The 5v ac adapter can be an alternative power supply.
Turn on the camera - check if it would do the same thing - like lighting up, making a noise (attempting to extend the lens) and closes. If it does, the camera needs to be sent in for repair.
visit www.kodak.com/go/itg to arrange repair
If you are using a photoframe dock2 or camera dock series 3 to recharge the camera's batt - use its 5v ac adapter. It will work with the cam. Make sure, the batt is not in it to check the cam's condition, isolating the possible interference of the battery.
If the camera works fine - when the AC adapter is attached, no battery in it - consider buying a new battery.
V610 is a very nice camera, but it was manufactured in 2006. If you have not replaced the battery yet, it might just need to be replaced. Even Li-ion rechargeable batteries wear out eventually - it can only last up to 300 charging cycles.
If you're using a batt that is less than a year old, the cam might just need to be sent in for service.
SOURCE: Cannot download pictures from camera to computer
What system Are You Using? Im Using windows Seven And Vista, It Will Not Work . Just Use Sd card Reader Or Flash Usb Sd reader.
SOURCE: Kodak Easy Share V1003 camera is frozen. Turned
Your fix could be as simple as cleaning the camera's battery contacts,
or it could be something more serious and expensive. Before you pay
for expensive repairs that you may or may not need, check the Kodak
Help Center by clicking on the link below. It uses a simple Q&A
format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
SOURCE: Kodak Easy Share CD1013 pictures won't download on Vista
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
The card reader will most likely also still be compatible with any new camera you buy in future.
Kind Regards
Andrea
