Sounds like your control board fuse(s) circled in red below have blown which can essentially prevent the refrigerator from turning on. The control borad is accessed from the back side of the frig and behind a screwed on panel. The problem gets worse though ... in that these fuses are NOT removable ... they are soldered directly to the board ... so the whole board has to be replaced or if you are extremely handy with electronics you unsolder the blown one out and solder back a new one
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
SOURCE: Our 3 yr old LG Model LFC25760SW French door
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
