SOURCE: Black and Decker Blender Model Number 675 Replacement Parts - Collar
http://www.thegourmetdepotco.com/store/store_partaccess_index.asp?ManufacturerID=5&CategoryID=1&gclid=CICJ0pWm0ZMCFQnIsgodnkhAhg
SOURCE: Power light blinking red
The tv is NOT in standby mode... it does not have a standby mode !!! But what is happening is.. your tv is getting lamp errors. this can be caused by voltage drops and spikes while the tv is on... and a factory reset can correct this. OR it can be one of two problems.. Bad Power supply or defective lcd panel.
SOURCE: plastic safety key broke Black & Decker table saw cat# 1736
Try sears .They shoul be able to get it eor you
SOURCE: Power light is green but screen is black
Do you get anything at all on the screen--like white writing at startup?
Even if your video drivers have become corrupt, they are not used until Windows actually starts.
It very well could be the flourescent backlight has gone bad. Can you adjust the brightness/contrast at all to see anything?
If those controls do nothing for you, then you're looking to get a new monitor.
Your monitor does have a sort of power supply for the backlight and that could be bad, but if you're not into taking it apart, then you are far better off buying a new monitor.
SOURCE: LCD Modular Board
what ive been told ist must be the right part
wonder if i can ask you for a little info as well on the lefthand side of the board there is a 3 legged part think its printed as 303 on board could you tell me that part number please thats on the chip thanks in advance
