My router model is dsl-2750U
SOURCE: is there other way to recover my old password
You dont have to reconfigure if all you did was change to dsl.
Unplug dsl modem. Unplug router. Turn off computer.
Wait at least 30 seconds, plug in dsl modem.
Wait at least 2 minutes, plug in router.
Reboot computer. All should be OK. If not, reply back, and I'll helo you further.
SOURCE: Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
SOURCE: Need connect HP Officejet 7210 printer into wifi domestic network
Check your drivers at Driver Detective
If your computer does not recognize the printer, try going into your printers in the control panel and go to add printer and see if it finds it.
SOURCE: The combined Paradyne router and
You buy a new one, you install it in the place of the other and you configure it following the manual - you will need the connection data from your ISP (username and password - they are in the contract).
If you no longer have it you can download it from here
http://www.zhone.com/support/manuals/docs/62/6218-A2-ZB23-10.pdf
d-link wireless router dsl-2750u showing red in power
