Had Magnatron replaced about a year ago. Assume it was a 700W instead of a 900W magnatron as no details can be found on the magnatron.
SOURCE: Oster Microwave/Convection/Grill
first, get your money back or get a replacement for no charge. now, unplug the oven for 15 minutes and try again. if no-go, then some device is faulty that only a tech can find
SOURCE: GE JVM1650
The owner's manual will give you the warranty length. If you don't have yours, you can find it here: http://www.geappliances.com/shop/prts/
You really need to call GE on this. Only they can answer if they will still cover it. GE Answer Center -800-626-2005, 24 hours a day, 365 days a year.
Otherwise, it may fall under your State's lemon laws. You can contact the Attorney General's office, usually via http://www.state.xx.us (where xx is your State's 2-letter abbreviation).
SOURCE: Noisy magnatron
First of all, if you press against the right side of the outer cover of the oven, does that lessen the noise? If so, it may be that a rubber cushion on the side of the HV transformer has fallen off.
If it had that hum but was not heating, I would first check the HV rectifier diode.
But since it's cooking, I would say your magnetron is on the way out.
Unless the warranty is about to expire, I'd continue to use it and watch and wait.
SOURCE: microwave cuts off after 3 seconds. Magnatron?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
SOURCE: takes about 6 min to
This an early indicator that the magnetron "heats the food" is failing, usually they will go without warning and eventually will need to be replaced.
