Save time and money on Cooker Cleaning
After cleaning your oven - do you want to ever do that again ?
Well, to cut oven cleaning down to a few minutes, just mix Sodium Bicarbonate (Bicarb) with a little water to make a thick paste, then spread it evenly on the base of the oven just using rubber gloves - it doesn't need to be too precise.
Put the oven on warm for a few minutes just to dry it out.
That's it !
Leaving it on the base of the oven prevents any dribbles or spills from sticking, and it doesn't leave any odours or harsh chemicals in there.
Next time you clean the oven - just use warm water and you will be amazed how it just lifts off - leaving your oven clean with no other chemicals needed.
Add another batch when you're done and it will continue to lift any areas you thought were impossible to get off.
The steam created while using this cycle is meant to help release backed on foods, but some elbow grease may still be required. For especially stubborn areas, you want to saturate the area with a Dawn Dish Soap and water solution and let it sit for up to 30 minutes. This may help get the grease adhered to the cooking surface off. You will then want to take a non abrasive sponge to wipe off the inside of the cavity. We hope this helps!
