E
Essang Posted on Jan 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I replaced the toner cartridge chip for my sharp copier AR 6020 and the error code f2-70 appears. How can I clear the error code.
Tareq Bin Mostaq
Level 2:
Champion:
  • Expert 205 Answers
  • Posted on Jan 11, 2018
Tareq Bin Mostaq
Expert
Level 2:
Champion:
Answers
205
Questions
5
Helped
112267
Points
323
IMPROPER CARTRIDGE.I mean cartridge chip destination error.or toner not supply properly.
Testimonial: "How can I solve this problem"
5 Related Answers
Anonymous
  • 148 Answers
  • Posted on May 26, 2008
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
san3409jl
  • 190 Answers
  • Posted on Jan 27, 2009
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Warrick Lee
  • 32 Answers
  • Posted on Mar 25, 2009
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Anonymous
  • 95 Answers
  • Posted on Apr 23, 2009
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Everett Lin
  • 990 Answers
  • Posted on Oct 09, 2009
SOURCE: My sharp copier AR-5316 has the problem. Error
Hello sir; You need to do a reset procedure as follow; Press "#", "interupt", "C", " interupt". then enter 14 press start, machine go back to normal.
4answers
How to clear errol f2 -64 on sharp ar 6020 copier
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
3helpful
2answers
Code erreur U2-40
U2-40, mostly appears in sharp copiers when you installing new toner cartridge.the reason of this code is faulty CRUM chip because of different type of toner manufacture .
you cane this problem by replace the chip in the new toner cartridge by the chip in old toner cartridge
- the chip is located in the rear toner cartridge -
I hope this help!
17helpful
3answers
Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
20helpful
3answers
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
16helpful
4answers
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
26helpful
5answers
F2 on appears the Display
Try reinstalling the toner unit. Then try replacing the toner. CRUM error. CRUM is a small chip on the Toner cartridge.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
