I looked up my bank account today and the deposit did not go through as advised. This is very bad PR and I want this matter taken of immediately, otherwise I will have no other option but to take other measures to recoup my winnings at your cost.
SOURCE: cannot install win 2k or win xp xp on biostar m7ncg 400 v7.2 mobo
use the CD that came with the motherboard. do a setup and configure the motherboard. you need to update the Chipset software in order for the motherboard to recognize the hard drive header.
SOURCE: Win XP CD repair wont accept admin passwd.
saidfrh1, you closed the prior thread too soon.
Okay, so no System Restore option.
First you can check the Admin password by trying to go into Safe Mode. Immediately after the splash screen, press F8 until the Startup option menu displays. Select the first option (Safe Mode) and then the Administrator account. Type in the password you think it is, and double check your Caps-Lock key first. I do not think it advisable to post the diections on how to remove such a password on this site.
But even verifying the admin password will NOT help you get this machine restarted and running correctly because there is nothing in the Repair Console to remedy the System Recovery option being turned off. There is nothing to go back to.
Since you obviously do have an installation disc, hopefully one that matches you OS (XP Home for Home or XP Pro for Pro), you have two more options.
First is run a System File Check, which is Window's way of fixing some damage to itself. It is not infallible, but it may restore enough missing files to get you running smoothly again. Go to the Start Button->All Programs->Accessories->Command Prompt. This will open a DOS box where you can type in the following command:
sfc /scannow
and press Enter. The routine will start, and it will take a while to complete. Hopefully it will prompt you to insert the installation disc so it can read and transfer the missing files to the hard drive. If the Windows XP Installer pops up from autorun just click cancel. Let this routine run all the way through, then reboot.
I have also had some success by reinstalling the latest Service Pack (currently SP3) to replace files the installer finds missing.
If that doesn't work, then you can do a Repair Installation. I'll wait to hear your results with the System File Check first as a repair install can be tricky (drivers, COA, etc.).
Oh, and I have no idea what ragmani69 is trying to suggest. It definitely would not work for your problem.
SOURCE: iwant to look for the pch win a seach to win the
PCH Search & Win ' Win Prizes by Searching, Search Engine ...
PCH Search & Win is a powerful search engine with a twist! Each search gives ...
search.pch.com/ - Cached - Similar
SOURCE: I need solutions mannual of
need solutions mannual of the text book, Cost Accounting, Planning and Control, 9th Edition, By Professor Matz, Hammer and Usry
SOURCE: how is interest calculated on recurring deposit accounts in banks
Recurring deposit interest is calculation may vary depends on compounding period. You have to invest an amount every month interest will be calculated for the current holding in your recurring deposit account. And every compounding period interest amount will be added into holdings or available balance. You can calculate the Recurring deposit using this recurring deposit calculator
