SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
SOURCE: My speed queen top loader is leaking water during
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
SOURCE: Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
SOURCE: how to take out the agitator assembly in speed
That agtator fits and locks into place by a hub under it,by grabbing the outer edges of agitator and pulling straight up it should come off. Its not made to come off to easily and may need some muscle when pulling up.
Gene
SOURCE: hi i have a speed queen toploder washing machine
It might need to be rebalanced or your connection are not tight.
