Something is depleting the battery or the problem is the battery itself. (Those power antenna is the worst depletion of battery.) Unplug the negative terminal for five minutes and see if it starts or just unplug the negative terminal and charge the battery for ten minutes and then reconnect the negative to see if it starts. (Insert car key and turn to the second position.) Once, I even have a wire from the Starter's positive side ready to contact the battery positive. The car started this way.
SOURCE: How to change the cabin filter on 2006 Honda Odyssey?
I will never understand why this service is so expensive at the dealership.
I made a video showing how this is done: (I would recommend watching the video in HQ and full screen)
SOURCE: Honda Odyssey won't start - flashing dashboard lights
Try a jumpstart. Can you honk the horn or use any electronics in ACC mode?
SOURCE: Honda Odyssey dvd player not working after having battery jumped
If you disconnect your battery for an hour and then reconnect, the dvd will just pop right out. This happened to us, Honda did not know how to fix it and they wanted me to pay $400 for a new one. But while they were trying to figure it out they were sticking screwdrivers and pens into it and have now broken the whole system and refuse to pay for it.
SOURCE: I need a radio code for my 2006 honda
Late response, but for those who still have code problems on radio; I found the code for my 06' Odyssey was on the first page of service manual. The Owners Manual reads that the code should be on a card with the owners manual. I didn't find that. Hope this helps someone.
