SOURCE: Franke safira reads Malfunction 4
error/malfunction 4 usually means thermistor/sensor on steam generator block has failed ie open circuit /disconnected......................small metal encapsulated device clipped or screwed to block,2 wires to harness plug...
SOURCE: our franke flair coffee machine keeps saying
this is usually due to the overtemp device activated on one of the thermoblocks, an engineer will be required to replace this item,
SOURCE: Franke coffee system, always same error message ''fill water tank''
What you would have to do is take the side panel off to get at the solenoid. It is probably sticking closed and not letting the water fill into the boiler.
SOURCE: I have a franke flair coffee machine when you
DESCALING
The Saphira has an integrated descaling program. The procedure takes about 60 minutes.
Once started, the descaling procedure may not be stopped.
• When acid-containing descalers are used, immediately remove any splashes or drops on
sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety
precautions.
• Turn off the Saphira by pressing the "ON/OFF" button.
• Press the button "Descale" until an acoustic signal is heard.
• Display: EMPTY
DRIP TRAY (Fig.1)
• Display: INSERT AGENT
IN TANK
• Display: PRESS
DECALCIFYING
Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty
water tank.
Place a sufficiently large container under the steam tube and the coffee delivery outlet.
• Press the Descale button
• Display: UNIT
DECALCIFYING
• Display: PLEASE
WAIT
• An acoustic signal is heard.
• Display: EMPTY
DRIP TRAY (Fig.1)
• Display: FILL
WATER TANK
• Display: PRESS
DECALCIFYING
• Display: UNIT
DECALCIFYING
• Display: PLEASE
WAIT
• Display: EMPTY
DRIP TRAY
• Display: CLEAN
CONTACTS
Good Luck
[email protected]
SOURCE: Got a malfunction 4 on a franke flair ? Any ideas
Hi.I think its a temperature measuring fault in the steam circuit. Most likely to be the thermal sensor on the thermoblock. Check to see if the sensor wires are broken or corroded. Can also be the control board. I'll put my money on the thermal sensor. Dazza REPAIRER
