hi there
the fuse that controls the cigerette lighter will be marked on the fuse box or cover cig or in some vehicles acc thank you and have a wonderful day
the radio & cigarette lighter usually run off the same fuse,check the fuse box under the hood for a blown fuse ,you may have another fuse box under the dash,check there also......hope this helps.........cheers
You can check if it's the lighter or the lighter terminal fairly easy, It's most likely you have a car cell charger or something similar that works by plugging it to the cigarrete lighter terminal, check if it works, if it does your lighter is bad, those are fairly cheap and you can buy one on a dealer store or a good auto parts store. Good luck
Check for power to your cigerette lighter by removing the wire connector from the back and probing with a test light. If you have power then it's your cigarette lighter itself. You can buy them at most auto parts stores.
Check you fuses..
If you mean - the sig lighter - the part you use to light a sig - is not getting hot - they do fail.. You can get a replacement at a auto parts store..
May be with other accessories like radio, or something. Might need to purchase a cheap 12v test light. Always good to have one around for such problems.
