SOURCE: Flashing red light and cannot eject game
PS3 has overheated and the thermal compound between the cpu/gpu and heat sync need to be replaced. the gpu and cpu may need to be reflowed as well. Had the same problem and fixed mine. The thermal compound was pretty much gone when i opened up the system. Also dont keep your ps3 on its side leave it flat this will help keep the compound from moving as much.
SOURCE: My Ps3 isnt starting, light turns green then changes to yellow
this is the ps3 equivilent of the xbox360s red ring of death error, sorry to tell you but that means a serious system error has killed your ps3 its unfixable and you will have to send it off for a replacement
SOURCE: my ps3 suddenely turned itself off mid-game.
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
SOURCE: my ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
