The draw a design to unlock screen can I get past it
SOURCE: how unlock phone LG 410 front tracfone ? Code:
Try restriction codes here
http://www.onlinegsmunlock.com/lg/rs7wp8/
taking the battery out will do it
SOURCE: How do I unlock my Trio Stealth 10.1 Tablet screen I tried to unlock it several times
If you locked it with a code that you can't remember, your last resort is a factory reset. by most tablets is accomplished by simultaneously holding in buying buttons and the power switch for at least one minute. Look through your user documentation it may have a slightly different procedure.
Once you do this you can go Google Play Store you can reinstall the apps by going to MyApps.go to the room list and reinstall them. Any licenses you had purchased should be stored at the Play Store. Your user data should be intact.
Caveat: if you encrypted the tablet you WILL lose all data that you stored on it.
SOURCE: MID model M729B can not get the tablet to respond to unlocking the screen
Here's a link to the manual:
http://www.mymidpad.com/M729B_User%20Manual.pdf
You need to do a hard reset which will wipe all data and restore the tablet to factory settings.
You can lock the screen of your HTC Hero screen with a draw pattern. Here's where to set the feature in the Android software.
1. From the Home screen, press Menu.
2. Tap Settings.
3. Tap Security.
4. Tap Set unlock pattern.
5. Read the info, then tap Next when ready.
6. See the pattern, then tap Next.
7. Draw the screen unlock pattern with your finger by connecting four or more dots in a row.
8. Tap Continue.
9. Draw the same pattern again.
10. Tap Confirm.
hope this helps
John
