Jedistarhttps://jedistar.com > alvarez
Serial number appears to have an A before numbers and then 5 digits like yours, 81613. It's stamped into bracing on the back piece, no sticker. Mine is ...
Alvarez Guitarshttps://alvarezguitars.com
Which guitar gives you unsurpassed value and quality? Which guitar is the one you keep reaching for? We believe that guitar is Alvarez. Why Alvarez. Featured ...
IF it's fret buzz, the solution can be simple or difficult. Usually means the neck is not right. Many ways to fix it, but the best way is usually by getting the neck just right. IF it's buzz in the amp from the piezo electric pickup, that's another problem entirely. Could be a loose ground wire, may need shielding, or may simply need to be attached better. Got to see it and hear it to determine what the problem is and the best way to proceed. Contrary to what people think, the neck should not be perfectly straight when under string tension. it actually should be bowed forward, but just a bit. Fret buzz is easiest to fix by raising the bridge. This can be done a number of ways, a shim under it is the quickest and easiest, but only when someone sees it can they tell what way to go. Sometimes, you need a taller nut. Trouble is, these will change the string height all along the neck, and playability sometimes suffers. I've seen them set so high that they were virtually unplayable. Me, I like them as low as possible without fret buzz.
Strings buzzing can either be the action being set too low, or the frets needing dressing or the neck not having enough relief or being actually warped. We can't tell from here.
Learn how to adjust the truss rod in your guitar, if you can. That's the easiest fix that does not involve specialized tools, filing frets, or disassembly. You may need to buy or borrow a long hex driver to reach the truss rod adjusting nut https://www.youtube.com/watch?v=xyqrSRI2asc&feature=youtu.be&list=UUM-CsUeK57J8grv9BSBRRhQ
If it is a simple relief problem, that may fix it.
Adjusting the height of the bridge requires taking out the bridge and shimming it, which involves some woodworking skills (unlike an electric guitar where you can adjust bridge height and intonation with screwdrivers and or hex wrenches)
This should be possible to fix, depending on the cause, but because this is an acoustic guitar adjusting the action, frets and any major neck issues is a job that should be looked at by a qualified person. Keep in mind that your Alvarez is not a hugely valuable guitar, so you want to set a budget and get an estimate.
You might try to find out through Google. It may be made in either China or Korea. As long as you quote the number of that model which should be on the inside of the guitar if you look through the hole in the centre of the top of the guitar where the strings run across. Best of luck.
Anonymous (may I call you Mous?), Alvarez serial # system is not as intuitive as say... Krylic haiku. But, If you are on Facebook, you can PM Alvarez via their FB page. Include a pic if you can, You should get an answer back in 72 hours or less.
