SOURCE: food thawing in freezer
You may have a small leak in the evaporator. You could try to get a replacement freon with stop leak from the automotive store and give it a shot. If it is a R12 unit then it is too old to repair. But it is worth the gamble to shoot it with freeze 12 or an equivilent before you condemn it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: kenmore upright freezer no digtal light no motor running
This could be a bad controller since you had a power outage, or even a bad motor. Look in your operator's manual and see if there is a reset button somewhere near the motor.
Unless you are well versed in electronics and have the proper equipment, you'll be unable to diagnose the control board anyway.
As a last ditch effort, which sometimes works, unplug it for about 5 minutes and then plug it back in. Make sure your thermostat is turned to the correct setting.
SOURCE: Upright Frigidaire freezer with warning buzzer on constantly
If your'e positive the temp is ok then your freezer cold control may be bad. Slowly turn it toward off. If the compressor doesn't cut off before it gets to off, the control is probably bad. Test it here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
SOURCE: I have a True Freezer, the compressor comes on but
http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
Go to this web site and look in the manual on page 15. Check "Compressor runs but will not refrigerate". Gives some suggestions.
Now, inside the evap, usually strapped or clipped to the coil "U" turn on the end of the coil, is a Klixon device. This device comes in many different configurations. There may be 1 or 2 of these. One is a defrost termination switch. When evap gets hot enough so no frost is present, it terminates the defrost cycle. The other is a fan delay. It comes on when the coil temp gets to about 20 degrees. This prevents circulating warm air from defrost cycle. Now if there is only one device, it can be 2 in 1. That is, a defrost terminator/ fan delay. Will most likely have 3 wires going to it where as the 2 separate ones will only have 2 wires to each one. Now, either this fan delay is not working correctly or the coil is not getting cold enough. When it gets cold enough, it turns on the evap fans. This is most likely where your problem lays. Check it out.
SOURCE: Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Testimonial: "Thank you for the response Fridgie!"
If the compressor is too hot to keep your hand on top it may be the=> 216649315_Relay-and-Overload-Kit
5304464438 Run Capacitor
Let me know if the compressor is hot and we will know the compressor is trying to start but cannot. Replacing these parts will possibly solve the problem of your freezer being on but not freezing everything, We need to make sure the compressor is running, Thanks Sea Breeze
